BALLAST INFO
/ BALLAST INFO #2
Good timing on this post. I usually run my L3301 with a rear scraper blade, but I remove it sometimes when I have to get into thought spaces. I was thinking of getting a heavy hitch with suitcase weights. Has anyone got a recommendation?
/ BALLAST INFO #3
I just build a 2x2x1 (4 cu-ft) steel box from scrap and filled it with concrete, weights in at approximately 600 lbs.... Lot cheaper than buying weights...
You might try doing a "search" for "ballast", lots of solutions posted over time....
/ BALLAST INFO #5
You can make your own for less than it would cost to buy suitcase weights. Here is just one solution:
  • 55 gallon drum on cross drawbar counter-weight - interior view of rebar.jpg
2015 RAM 1500 4 X 4 CREW CAB PICK UP TRUCK (A59914)
2015 RAM 1500 4 X...
2015 Ford E-350 Shuttle Bus (A64556)
2015 Ford E-350...
2008 12ft. Alumacraft Flat Bottom Mud Boat (A64194)
2008 12ft...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
2009 Ford F-150 Pickup Truck (A64194)
2009 Ford F-150...
Trek (A65640)
Trek (A65640)
