Home made plywood
   / Home made plywood #21
IMO the best uses for something like what has been called 1/8" plywood...would be for applications that require forming curved frames etc...
Some curved staircases are made this way...skateboard pipe sections etc...things like water skies or snowboards could be encapsulated...
For marine applications or use in wet locations I would not use anything but resorcinol glue and that costs the average consumer about $45/pint...!
   / Home made plywood #23
I make small pieces of plywood (aprox 12inch sq.) out of veneer using Tite bond 3 for glue. I use it for small projects that I build, and for scroll saw projects.
SR
   / Home made plywood #24
build a vacuum table
Get ahold of some inner tubes And build an air pressure clamp system.
Maximum vacuum is less than 15-psi. You could build an air pressure clamping system and get close to 100-psi pretty easily, and could go higher with a bit of design effort.
   / Home made plywood #25
I think you would be better off laminating them together as needed. Rather than gluing 4x8 sheets together to make a 3/4" sheet and then later cutting the 3/4" sheet into 1ft × 4ft sections to make a shelving unit, just wait until the shelving unit project comes up and cut the 1/8" sheets into 1ft × 4ft sections and glue them together. There are a few benefits to this as I see it:
  • You don't waste glue on parts that will end up being scrap
  • It is way easier to glue & clamp small pieces than entire sheets. In the hypothetical example of 1ft × 4ft shelves you could cut up dozens and dozens of them, put glue between the pieces you want laminated (and no glue between the pieces you don’t) and laminate a whole unit worth of shelves at once, with one set of clamps.
  • You can skip the step of routing slots by simply leaving gaps in your laminations
  • The 4x8 sheet gluing process is going to take up an unreasonable amount of real estate in your shop. Doing it on smaller scale on an as-needed basis won't take up any more room than a given project would have taken if you bought 1/2" or 3/4" ply
  • Never know, maybe one day you actually need 1/8" ply. Would be a shame to have just had a load of it but you glued it all together.
   / Home made plywood #26
And by laminating as needed, you could press in structural components as needed. Want a book shelf to hold five feet of books without sagging: Roll a lip int the front and back of the shelf to stiffen it up.
   / Home made plywood #27
Back in the early '70s I knew an old backyard boat builder who used to tell about stopping by a boat factory in Florida to see how the pros did it. He said they bent and glued them up one ply at a time to get the shape they wanted. I took these boats to be cabin crusers.
   / Home made plywood #28
You’re going to need a pretty significant frame to hold 100 psi over a 4x8 sheet. That’s 460,000 pounds.
   / Home made plywood #29
My uncle made his own dog leash once, out of a piece of rope.
   / Home made plywood #30
+1 on that. Finding 1/8" can be hit or miss. Generally 3/16 is the thinnest I can find, which makes it much harder if you need to bend it (especially small projects like the doll cradles I built a few years ago for my wife's granddaughters).
   / Home made plywood #31
So yea,I plan to buy a log peeler and,,,,,,:giggle: not really but I can buy used 1/8" plywood 50 sheets for $50 and endless availability. Have you glued up multiple layers to make thicker sheets (I'm thinking 4 to 6 layers) and how did it work out? I'm thinking of sand bags for clamping. If no previous experinece,does it sound like a worthwhile porject? i would mostly use it on shelves,pallet rack and interior wall covering for storage buildings.
Sometimes you need to ignore the "Good Idea" fairy.
   / Home made plywood #32
They make big vinyl heavy duty bags for gluing assemblies while using a vacuum pump to get a loading of 15 psi. I'd like to have one of these.
I did laminate 3 sheets of plywood maybe 24X36", with the middle one oriented 90 degrees differently, to create a heavy "deck" for a 3PT platform lift. I've also done this with 2 sheets 4X8' to create a big work table. I used bags of cat litter to create pressure, though obviously far far less than the 15 psi a vacuum bag would create. Both these projects turned out as I wanted.
   / Home made plywood #33
sell it to those people who renovate small old campers, they had nothing but thin plywood on the walls and ceilings.
   / Home made plywood #34
You can use saw horses for the base and then 2x6 or
2x8 or 2x10 or 2x12 screw boards into them so they
can't move the space has to be at least 9 ft by 5 ft to
put blocks on the corners to hold the 1/8 x4x8 sheets
then you can glue 4 or 6 sheets together for you side
walls, roofing etc. and you can use clamps to hold down
the plywood while it drys
I read that this stuff is stronger than glue and coverage
is 150 to 180 meters and a sheet of plywood is less than
10 meters Polyvinyl Acetate Emulsion Polyvinyl Acetate Emulsion Glue for Furniture Assembly(id:11558192). Buy China Polyvinyl Acetate Emulsio - EC21
Add up the expense: 50 sheets of 1/8 inch plywood $50
price of glue 5 gal tite bond 11 $121.64 x 2 = $122.28
TOT $172.28
1/2x4x8 plywood $39.56 x13 = $514.28 - 172.28 = $342.00
Is gluing the 4 plywood sheets together worth it?????
willy
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
2015 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59905)
2015 FREIGHTLINER...
2008 GMC Savana 2500 Cargo Van (A59230)
2008 GMC Savana...
2011 CATERPILLAR 279C SKID STEER (A60429)
2011 CATERPILLAR...
2012 Ford E-250 Cargo Van (A59230)
2012 Ford E-250...
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
