R14 replacement for 13.6x24
/ R14 replacement for 13.6x24 #1
fatbacks
Massey Ferguson 1735M
Hello,
I'm looking at a massey fergusion 1735M with 13.6x24 ag tires and wondering what size R14 might fit. Tractor data list different options but do they all use the same 24 inch rim?
Tractordata lists:
- 12.4x24 AG --> 320/85R24
- 13.6.x24 AG --> 340/85R24
- 17.5L-24 R4
Can't find a good explanation the first number. One site says it is the thickness of the tire from the ground to the rim. Other says it's the width.
thanks
/ R14 replacement for 13.6x24 #2
12.4x24 is a 12.4 inch wide tire on a 24 inch rim;
320/85R24 is a 320 mm wide tire with a sidewall height that is 85% as tall as the width on a 24 inch rim.
So 320 mm wide with a sidewall that is 272 mm high on a 24 inch rim.
/ R14 replacement for 13.6x24 #3
Im not familiar with metric sizes but a 17.5 x 24 has a far wider rim vs a 13.6 x 24.
I talked to a dealer and they said 14.9-24 would the same rim as a 13.6x24. I found both tires using 12" rims. Are 12" rims pretty much standard for 13.6.x24 tire? I found some Goodyear R14s in a 14.9-24 size that call for a 12" rim.
/ R14 replacement for 13.6x24 #5
Best thing to do, is to go to the manufacturer website of both types of tires you're comparing, find the specs and more often than not, they will list what width rims will work for a given tire size.
Depending on the tire, it may even list 2 or 3 different rim widths.
/ R14 replacement for 13.6x24 #6
Hello,
Tractordata lists:
- 17.5L-24 R4
thanks
- 17.5L-24 = 460/70LR24
/ R14 replacement for 13.6x24 #7
Hello,
Tractordata lists:
- 17.5L-24 R4
thanks
It's simple. Both numbers are wheel numbers. They tell you the size wheel that tire fits best and is the wheel size the manufacturer used when making all the other measurements like distance from the ground and rolling circumference and diameter.
The first number you are asking about is the width from the inside surface of the wheel rim to the opposite inside face.
If you use a wheel with the proper dimensions, then all the rest of the manufacturer's measurements will match their specs.
Obviously, you can put a tire on a little wider or thinner width wheel - but then all the other tire specs will change as well.
rScotty
/ R14 replacement for 13.6x24 #8
rScotty
Not sure I understand what you are saying? None of the numbers he posted tells you the rim width. Lou did a great job of explaining the numbers posted.
/ R14 replacement for 13.6x24 #9
Most important number is the RCI (rolling circumference index) of each tire. If you are changing from an R1 of any size to an R14 you need to be concerned about the RCI. If the R14 doesn't have the same or very close to the same RCI you will be changing the gear ratio of that axle. This can cause serious binding issues.
Here's an old RCI chart I've had for several years. It gives you the RCI for your R1 tire. But R14s weren't in use when it was created.
Google search an updated chart.
  • RCIChart.pdf
/ R14 replacement for 13.6x24 #10
Tire Calc helps you figure out circumference. Many others on line.
/ R14 replacement for 13.6x24 #11
The first number does. Also read the first sentence in Lou's reply (#2). He and I are saying the same thing.
/ R14 replacement for 13.6x24 #12
First number is TREAD WIDTH, not rim. You can have a lot wider tread than rim depending on tire.
/ R14 replacement for 13.6x24 #13
I just go to the manufacturer's site and look in their technical specs. Rolling circumference is important for part time 4wd, and has to be measured rather than calculated. So it is usually in their tech specs. But hardly ever mentioned in their sales specs.
And Rolling Circumference is absolutely dependent on using a wheel that matches the tire numbers.
rScotty
/ R14 replacement for 13.6x24 #16
Go to ANY tire place and see what will fit on your rim. You can normally go one width down and 2 or 3 wider. Stock on my Magnum is 225/60-18 I'm running 245/55-18 and have used 255/50-18
Rim is 7.5 wide.
/ R14 replacement for 13.6x24 #17
Yep. This is proven when comparing R1 tires to R1W tires. I gained 2" of tread width with an R1W using the same rim that the R1 came on.
/ R14 replacement for 13.6x24 #18
Actually I was wrong my wheel is 8.5" but here is chart for reference.
/ R14 replacement for 13.6x24 #19
Please correct me if I'm wrong, but this looks like an automotive tire/wheel chart to me, providing guidelines for that use.
Tractor tires likely have different requirements and may have more relaxed guidelines considering a very different use.
Definitely look at some tire possibilities and check manufacturer specs carefully for applicability to your use (ie, wheel size).
It's been mentioned above that 4wd places other size requirements - typically you need the ratio of the back:front tire circumference to remain similar (especially if you operate in 4wd on pavement ever). I'd advise checking the OEM tire's rolling circumference and make sure either you replace with almost identical rolling circumference, or you replace the fronts at the same time such that you keep the same ratio between front & back tire circumference (ie, if you're putting smaller circumference tires on the tractor - which will lower ground clearance, but also lower CoG for increased stability if you have a lot of hills - IIR @ericm979 got his tractor set up like this when he bought it).
/ R14 replacement for 13.6x24 #20
Just trying to show that the first number is NOT rim width and different width tires will fit on the same rim. Of course you need to match rolling circumference for 4x4 and if you want a speedometer to accurate.
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
2018 VOLVO VNL 670 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 VOLVO VNL 670...
2007 HEIL TRAILER (A65643)
2007 HEIL TRAILER...
60in. Loader Forks and Frame Attachment (A61572)
60in. Loader Forks...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
Used 20' Container (A62679)
Used 20' Container...
