ruffdog
Super Star Member
- Joined
- Dec 31, 2011
- Messages
- 12,518
- Location
- America's Dairyland
- Tractor
- Bobcat Toolcat 5610G, Deere X744, Cub Cadet IH 982
This is an old one made by Warner Instrument Co in Beloit WI
Ahah! OK, thanks for that. Sounds like all this theory is overthink. If I had not found out about it, I would have just experimented until it sounded and felt right. Back in my younger days that's what I used to do.It's very common for these smaller Japanese tractors to have 4 PTO speeds. Something like 540 - 750 - 860 - 1000. All achieved at the rated RPM, probably in the 2500 engine RPM range like Ruffdog says.
It's also common to use the 750 RPM with less engine RPM to achieve 540 PTO RPM with less engine RPM, also known as 540E (E for economy).
And even more so, reduce torque for the implement. But that's where you drop the _tractor_ gear and just move slower.It should be noted that running a higher pto gear at a lower engine speed will greatly reduce available HP.
Thanks for that idea. It is good. There are actually a couple of sites ... Online Tone Generator - Free, Simple and Easy to Use....for instance. Does all the standard wave forms.A 6 spline shaft at 540 rpm would generate 3240 square wave beats per second if it made contact with a flexible strip. Remember clamping playing cards to your bike wheels ?
Then ask Google to play you a 3240 Hz. tone on your phone and compare the 2 tones. Adjust the throttle accordingly in any of the transmission selectors. The tone is actually played on a youtube clip loaded with your specified frequency. Try it ! Even though the generated tone is a sine wave, you can't miss the hook up (well yas you can if you're DEAF, but that would kill the mood). As you get close to a match, you might hear a beat frequency as the difference between the two signals. Ignore any sharks that might appear in the area....
Incandescent lighting doesn't really flash, because the filament itself is incandescent, and it doesn't markedly change temperature/light output during the brief interruption of power.Thinking outside the box, would this works using a standard 60hz incandescent light?
Find where 600 PTO rpm is (because it works well with 60 sec/min and 60 cycles/sec.) as follows:
The PTO shaft turning 600 rpm, means 10rev/sec. The PTO shaft has 6 splines. At 10 revs per sec, that means 60 splines pass by per second.
An incandescent light operating at 120v/ 60 hertz flashes 60 times per second. That means, the splines will look like there not moving when PTO is at exactly 600rpm. (“Strobe effect”.)
Once you know engine rpm for 600 PTO rpm, multiple that by .9 for 540 PTO rpm engine setting.
The problem, you might also observe “stand still” strobe effects at 15, 30, 60, 120, splines/sec, (150, 300, 600, 1200 rpms, maybe others?), so you have to know you’re operating in the right ballpark when looking for the 600 rpm strobe effect.
Suuuuuure, that’ll work…..in theory!![]()
Why not????Well I certainly do not want to run my engine at 2500! Anyway does that have anything to do with a 4-speed PTO, or refer to my question?
Fluorescent lighting does flicker with the cycling, and many people can see the flickering at 60Hz. You'd be better off using a fluorescent.
Yep. That's what the tractor is designed for. And that RPM is probably where the tractor is making peak HP/power. It's the RPM that *should* be used for running a PTO-driven implement. Certainly there are situations where load is light and rotating speed isn't important and you can run at different RPM, but those are the exceptions, not the rule.Why not????
Tractors are designed to run at rated power & rpm all day long everyday for many thousands of hours.
PTO operated equipment is designed to be run at a set speed typically 540 or 1000 rpm for most North American tractors. Run at lower speeds may not operate effectively, but some do okay at lower speeds.
Well apart from anything else, I don't particularly want to sit on a diesel at 2500 RPM, and there are the neighbours to consider. The difference between 1500 and 2500 RPM in regard to noise and vibration is pretty steep.Why not????
Or an LED? A lot more compact. I suppose there is the problem with mains voltage, but there are lots of LED mains bulbs out there.Plus I’m wrong about 60 flickers per second, it would be 120 flickers per second..but I think* interference patterns would be similar.
Most tractors will run pretty smooth at pto speeds and rougher at slow rpms. Maybe there is a mechanical issue with your tractor that if repaired, would make it more enjoyable.Well apart from anything else, I don't particularly want to sit on a diesel at 2500 RPM, and there are the neighbours to consider. The difference between 1500 and 2500 RPM in regard to noise and vibration is pretty steep.
I will just have to try gearing and engine speeds to find the sweet spot.
No it's in good condition (it was overhauled before I bought it) and starts and runs well. I guess it's mainly the noise of the exhaust. At anything up to 1500 RPM it's pretty mild, but as it ramps up it gets a lot louder. I wear earplugs, but I am still conscious of the neighbours.Most tractors will run pretty smooth at pto speeds and rougher at slow rpms. Maybe there is a mechanical issue with your tractor that if repaired, would make it more enjoyable.![]()
I have a compact international 234 diesel, I was debating to get a pto generator or a gas. when I seen the pto generators needed to run at 840, I checked for the pto speed on my tractor,it would need to run at 2200 RPM's to get 840 at the pto. I bought a gas generator. I didn't want the engine to run that long at 2200 rpm. but I would run yours at that RPM since it is not for half the night and all day at a time. I would see no problem with 2200.I DAGS and searched the forum for PTO speed etc.
So. I have a Hinomoto N279 32HP tractor. Maybe I bought badly as it does not even have its own section here
However.. The N279 has a 4 gear/speed PTO. I know the flail mower I have bought requires a 540 RPM PTO speed. But I do not know for the N279 what PTO speed results from what engine speed in each PTO gear. The Tacho has no indication of PTO speed for each PTO gear.
So how do I measure the PTO speed? I tried writing on a spline with liquid paper. But 540 RPM is what.... 9 per second. Try counting that.
To add to that, the 4 PTO gears do not make sense to me: they do not go 1=slowest 2=a bit faster...etc. They seem to duck and dive, based purely on non-measure obs.
Or do I just wing it, going as high-gear as I can without labouring, running at 1500 RPM of the 200RPM of the N279, and yet getting a decent thrashing?
I understand that the whole thing revolves around also looking at Forward Movement Speed and is all a balancing trick. But I would like to know the figures as a starting point.
Excellent idea. My Kubota M7-171 has the equivalent. Most tractors that have multiple PTO speeds assume PTO speed depending on gear ratio selected (in my case the tractor has 540 and 1000 rpm and in addition 540E and 1000E). Instead of marking engine speed at which you should get a certain PTO speed, mine has a sensor similar to your add-on but built into the housing with sensor lugs on the base of the output shaft. On my multi-function display, I can read the exact PTO speed. In fact most farm size tractors have a PTO speed sensor so they read speed rather than have the operator assume the speed. Maybe someday they will work their way to CUT's.I went ahead and added a 12v digital tach even though the new dash has a tach. I wanted to verify the accuracy since my tach is driven by a cable. Come to find out. it's spot on. The push-on/push-off switch and the box are waterproof as is the sender. The sleeve on the output shaft has a magnet and set screw.
Your tractor diesel engine was designed to be ran at its operating RPM all day. You will actually run a greater risk of damage at a reduced RPM and and heavy load.Well I certainly do not want to run my engine at 2500! Anyway does that have anything to do with a 4-speed PTO, or refer to my question?
