NH Tc30 hydraulic help
/ NH Tc30 hydraulic help #1
Calhuon
New Holland TC30
New hoses for loader on my TC30 and I need to match the 4 hoses from quick coupler end to steel hydraulic lines. The color code rings on steel lines no longer exist. A pic or 2 would help. Thanks
/ NH Tc30 hydraulic help #2
Don't know if this will help. It is from the 7308 parts diagram.
  • nh-141754-299061-1308157.pdf
/ NH Tc30 hydraulic help #3
I don’t have a picture, but I believe the lower set is for the lift and upper set is for the bucket. If the operation of the circuit is backwards, swap those hoses.
In other words, the circuits are top pair bottom pair.
Still haven't figured out the match up
/ NH Tc30 hydraulic help #5
On my TC33D's 7308 loader QC plate the bottom two hoses control the loader's raise and lower cyclinder, the top two control the bucket cylinder's curle function:
/ NH Tc30 hydraulic help #6
Follow the lines from the lift cylinders back to the hoses to find the two for the bottom ports and then plug the other two (bucket hoses) into the top ports. If the operation of each of those is backwards, switch ports left to right or vice versa
Thank you everyone! Trial and error + noticing tiny arrows and quick coupler connection plate
/ NH Tc30 hydraulic help #8
Similar problem! Are the arrows actually on the plate?
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2024 John Deere TX (A64119)
2024 John Deere TX...
1998 MAC 39' Frameless Dump Trailer (A66285)
1998 MAC 39'...
2023 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2023 Chevrolet...
2009 IC Corporation PB105 School Bus (A64194)
2009 IC...
JOHN DEERE 4110 TRACTOR (A64280)
JOHN DEERE 4110...
