What else do you do with forks besides lift pallets?
   / What else do you do with forks besides lift pallets? #532
Poor mans forks that get by.
Using my box blade mount straps to the 3PT and a drawbar.
   / What else do you do with forks besides lift pallets? #533
Used my forks to change large heavy tires or lift trucks (one end) onto jack stands when needed.
Put the forks close together so they are just on either side of a tire then lift that corner of the vehicle
   / What else do you do with forks besides lift pallets? #534
They are handy to have, I made a cage that I can get in to wash the house, trim trees and a whole host of other things.
   / What else do you do with forks besides lift pallets? #535
Bought one at HF years ago, still works.
   / What else do you do with forks besides lift pallets? #536
Not really forks but I added a receiver tube to my mask and now I can move trailers with the front.
   / What else do you do with forks besides lift pallets? #537
Work platform to reach gutters, yard lights, tree branches.
Throw a sheet of 3/4 plywood on the forks for a portable outside work table. Or run the riding mower or 4-wheeler on it and lift them to a comfortable working height, push mower too.
Load empty pallets on wagon and pull to the woods landing. Grab an empty pallet, set it right next to the tree (or wood splitter) and load with green wood. Carry back to landing and set on wagon. Repeat. Unload at home when (if) you need the empty wagon.
Never touch it again until you grab the wood to put in basement.
Made a box for leaves, fallen branches and garden debris, 8 feet wide, 4X4 ends with a backwards tailgate. A pair of short chains, permanently mounted to the forks, retains it when I lift and dump. Boy, I can really pile that stuff up on the debris pile before burning it.
   / What else do you do with forks besides lift pallets? #539
Scoop puppies! She's 65+ pounds now lol
Lift mowers for access to get the sticks branches out of the blades.
Finally, some good uses. I might just keep my bucket. Besides, we all know, puppies may show up at any time.
   / What else do you do with forks besides lift pallets? #540
remove the tank from an IBC tote, cut an access hole in the cage, chain it to the fork frame, chain across the access hole, and you have a nice little work platform.
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
2022 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A55973)
2022...
2017 VOLVO VNL64T300 TANDEM AXLE DAY CAB (A58018)
2017 VOLVO...
HAMM HTC15 TRENCH COMPACTOR (A52709)
HAMM HTC15 TRENCH...
2021 Bronco 255K XD Welder Generator (A55973)
2021 Bronco 255K...
2016 GENIE S-65 TELESCOPIC BOOM LIFT (A52709)
2016 GENIE S-65...
