etpm
- Joined
- Jun 30, 2021
- Messages
- 2,358
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Greetings All,
I recently had my well pump, piping, and wiring replaced. I had intended to buy a Cycle Stop Valve and have it installed when I replaced my pump this coming summer. My pump failed ahead of schedule though. I called the guy who replaced my pump and asked him about pulling the pump he just installed to install the valve. He really doesn't want to do the job but does agree that the Cycle Stop Valve is a good idea. I can call someone else to pull the pump and pipe but am thinking about doing it myself. My well is only 60 feet deep and now has plastic pipe. To install the valve I would need to pull the pipe up about 10 feet, cut and thread the PVC, install the valve, and then lower the whole mess back down the hole. I am pretty sure the pipe is one inch and the valve is 1/14 so I will need reducers. I could glue reducers but I am worried the glue joint may fail. It should not but I am worried I may goof it. I may have the dies to thread the pipe and if I do then that's what I would do. If I don't, then I will need to use glue. Anyway, just how hard would this be? And can I trust glue? I can use the bucket on my tractor to attach a winch or a come along and then pull the stuff up to do the work.
Thanks,
Eric
i
Thanks,
Eric
i
