Ford 754 backhoe bucket pins
/ Ford 754 backhoe bucket pins #1
HUTCHAMUSPRIME
Ford 5000, 8n sidemount, 4500 backhoe
Hey all. My ford 4500 with a 755 backhoe (I'm pretty sure atleast) has 2 wrong pins in it I'm pretty sure. The previous owner replaced one with "the biggest pin TSC had" I have the 755 manual but not the parts manual. I'd like to find the right pins but I'm not having a ton of luck on the Ole Google. Anyone just happen to know the bucket pin size or type? Thwae are the 2 the Pins that attached the bucket to the idler arms.
/ Ford 754 backhoe bucket pins #2
I would suggest you measure the length and ID of your pin holes
/ Ford 754 backhoe bucket pins #3
If I remember right, they were 1 1/2“ x 12 1/2”
/ Ford 754 backhoe bucket pins #4
Dont know the length but 1-1/2" is the right diameter.
Original pins are very hard on those. Like Rc55+ range for both the pins and bushings.
IF you are gonna start down the hole of replacing pins and bushings on that thing....You better make friends with a local machine shop
/ Ford 754 backhoe bucket pins #5
Yea, they were about $200 a piece when I left Ford in the late 90’s
Wow I wouldn't have thought theu would be so much. One of these might be the correct pini just feel like there's too much play in the bucket. I've sheared off one of the retaining pins for those pins already. I just can't imagine that it should be moving around so much to have that kind of play. I'm no backhoe operator by anymeans but I didn't realize they were 200 each sheesh.
Only the things that I have to🤣 the bucket pin has come out twice now and it just doesn't seem right. I wish I had one to look at in person to get the right pin sizes.
/ Ford 754 backhoe bucket pins #8
You can order stock in different through or surface hardnesses from McMaster Carr or other suppliers and cut to length / drill for pins. Would be less than the $400 you're looking at but would require additional work
/ Ford 754 backhoe bucket pins #9
ouch!!!! salvage yard or machine shop time!!!
24 PIN 38.05mm OD x 318.3mm L 7704796 $487.20 Dipstick, 1-1/2'' x 12-1/2'', Bucket to Dipstick & Link Assy.;Effective W/1972 Production
dipstick and pins
This is what I'm working with. Call me stupid but I don't think I see any kind of bushing in their either.
/ Ford 754 backhoe bucket pins #11
I would think that the too small pin hammered out the bushings long ago, hate to see what the end of the stick looks like!
/ Ford 754 backhoe bucket pins #12
That is one of the cheaper pins.
on a 5500 the main pivot backhoe pin is even pricier -If you can find it
one pin $340
/ Ford 754 backhoe bucket pins #13
Bushing is in the boom. Looks pretty tight to me. Learn to operate it and the slop won't bother you a bit. Or, you can spend a few grand on new bucket ears, pins, boom bushings. I mean, if you gonna fix any of it, you need to fix it all. Like pop said, you can't polish a turd.
Or just keep it greased and keep rolling along.
I'm just gonna SEND IT
