Yanmar 3TNE84 rebuild kit
   / Yanmar 3TNE84 rebuild kit #1
MTGreen
Montana, USA
Deere 5220, Ford 1720, Deere Progator 2030
I have a Yanmar 3TNE84 3 cylinder diesel generator motor that is getting tired after a former life of many thousands of hours in a turf mower.
I don't know exactly how many hours as the hour meter was broken long before I pulled the motor, but it's seeping oil from a number of places & doesn't run smoothly under 1200rpm or so.
It's about time for a rebuild.
Complete aftermarket rebuild kits for these are plentiful and cheap with new cylinders/pistons/bearings/seals/valves/guides/seats/etc. readily available from a number of sources for less than $500 (US).
I'm curious about the quality and longevity of these kits and would like to know if anyone has any experience with these being good/bad from a particular brand or seller?
I don't use the genset very often, so I'm not real keen on ponying up several grand for OEM Yanmar parts. It's on a small trailer with a 15k generator head and is used for power, welding, and compressed air when needed remotely around the property. After rebuild, I plan to figure out what's needed to safely be able to hook/unhook it to the house/shop as backup power. I would have the expectation of a somewhat shorter lifespan from aftermarket parts.
Bump for maybe someone with input?
   / Yanmar 3TNE84 rebuild kit #3
You may have better luck on the classic Yanmar page. This isn't a current engine model, Fredericks and Hoye may be worth looking at.
Thanks
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
2025 LandHonor LHR-EW20000 20,000lb Electric Cable Winch (A49461)
2025 LandHonor...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
2024 WABASH STEP DECK TRAILER (A51222)
2024 WABASH STEP...
PAIR OF TALL STACK PIPE RACKS (A50854)
PAIR OF TALL STACK...
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
