Ford 7700 4wd wont run
   / Ford 7700 4wd wont run #1
Jamsmik1
Ford 7700
have and old ford7700 i want to ask if anyone know whats wrong with my tractor. The tractor wont run when i engage 4 wheel drive. It seems like the front wheel is stuck.it runs wheel engaged back to rear wheel drive.
   / Ford 7700 4wd wont run #2
Maybe you could describe in a little more detail what happens. The tractor won't MOVE in 4WD? The front wheels don't turn, just skid? They roll okay in 2WD? None of the wheels turn, the engine stalls? Give us something to work with here.
The tractor runs but only when 4wd is not engaged. When its engaged the front wheel looks like its jammed.
   / Ford 7700 4wd wont run #4
I'm not sure where to start, other than to disconnect the front axle driveline and see what changes. If it still won't roll, I would drain the oil from the transfer box and see what falls out.
   / Ford 7700 4wd wont run #5
Or, jack up the front axle and turn one side to see what happens. Listen and watch to see if it is a hub or the differential. Whe the tractor is off, the 4wd is engaged so the driveshaft will not turn.
Only other place where a problem would be is the transfer case where the 4wd driveline comes out of the rear end, but not likely
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2023 Kubota Z252KH-54 Zero Turn Mower (A56436)
2023 Kubota...
MURRAY PUSH MOWER (A58214)
MURRAY PUSH MOWER...
Westendorf 400 bu Gravity Wagon (A59814)
Westendorf 400 bu...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2019 GALYEAN...
