John Deere Z425
/ John Deere Z425 #1
melvinhatcher
Maryland
1948 John Deere M and 2016 Kubota L3301
/ John Deere Z425
Can I install this sprayer on my z425 zero turn?
/ John Deere Z425 #3
That pump draws 6.4 amps. What are the specs for the engine alternator ? Zero turns generally have charging systems that barely charge the battery and power a couple of lights.
/ John Deere Z425 #4
What is the capacity of the tank? I installed a 15 gallon on the front of my 717A. For me, I don't know if I would want much larger than that. RJ is right about the pump. That's quite a bit of amp draw. I guess it depends on how much you use it. Do you not have a SxS? That's what i spray with now.
/ John Deere Z425 #5
Powering a sprayer isn't typically a problem. Heat of the exhaust or weight can be, more so if the terrain is a factor. Consider a front mount.
/ John Deere Z425
It’s a 25 gallon sprayer.
/ John Deere Z425 #7
The charging system is more than enough to power the pump, even if it is constant run- which is not typically the case. Once started, the other load on the system is just the anti-backfire solenoid.
Edit: Looked it up, it is a 16 AMP.
/ John Deere Z425
Thanks to everyone for your helpful feedback, I have considered all comments.
I originally purchased this sprayer for my John Deere 318 which I stop using a few years ago. After reviewing all comments, I have decided to revisit my old 318 and her up and running again this summer.
Again thanks to all.
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
Vermeer 5400 Rebel Hay Baler (A61166)
Vermeer 5400 Rebel...
CATERPILLAR GC25K STRAIGHT MAST FORKLIFT (A62129)
CATERPILLAR GC25K...
2010 Dodge Charger Sedan (A61569)
2010 Dodge Charger...
CATERPILLAR T40D STRAIGHT MAST FORKLIFT (A62129)
CATERPILLAR T40D...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
