John Deere Z425
/ John Deere Z425 #1
melvinhatcher
Maryland
1948 John Deere M and 2016 Kubota L3301
/ John Deere Z425
Can I install this sprayer on my z425 zero turn?
/ John Deere Z425 #3
That pump draws 6.4 amps. What are the specs for the engine alternator ? Zero turns generally have charging systems that barely charge the battery and power a couple of lights.
/ John Deere Z425 #4
What is the capacity of the tank? I installed a 15 gallon on the front of my 717A. For me, I don't know if I would want much larger than that. RJ is right about the pump. That's quite a bit of amp draw. I guess it depends on how much you use it. Do you not have a SxS? That's what i spray with now.
/ John Deere Z425 #5
Powering a sprayer isn't typically a problem. Heat of the exhaust or weight can be, more so if the terrain is a factor. Consider a front mount.
/ John Deere Z425
It’s a 25 gallon sprayer.
/ John Deere Z425 #7
The charging system is more than enough to power the pump, even if it is constant run- which is not typically the case. Once started, the other load on the system is just the anti-backfire solenoid.
Edit: Looked it up, it is a 16 AMP.
/ John Deere Z425
Thanks to everyone for your helpful feedback, I have considered all comments.
I originally purchased this sprayer for my John Deere 318 which I stop using a few years ago. After reviewing all comments, I have decided to revisit my old 318 and her up and running again this summer.
Again thanks to all.
2018 CHEVROLET TAHOE (A66091)
2018 CHEVROLET...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
2012 FORD F-550 SUPER DUTY (A67714)
2012 FORD F-550...
Giyi PDQ QA Mini Land Leveler (A64912)
Giyi PDQ QA Mini...
2016 Chevrolet Suburban 4x4 SUV (A66738)
2016 Chevrolet...
SKLP 20'x30' Carport (A64912)
SKLP 20'x30'...
