Carport Weight
/ Carport Weight #41
i agree with the stronger during the move, the issue is that after the move the welding will have heat treated the 14ga and it may not maintain the proper strength this is IMO.
If it were me I'd be more concerned with the structure failing during move. I think those uprights are every 20-24" on mine so imo when it's static there's a lot more support to carry the weight of a few slightly weekend square tubes. I'd also direct my welding arc to the actual braces not the permanent uprights or baseplate. It's also not going to require a lot of heat to get a decent weld imo. I'd grind where it's galvanized to prep it and an old timer told me to minimize breathing in fumes when welding galvanized.
/ Carport Weight #42
It will fit on a trailer, buildings are trailered quite often. I have a 20x24 garage that was delivered and set in place.
Here is a pic of the neighbors 16x24 garage going down the road to it's new home.
you do realize we are talking about a metal carport type building 2.5" tubes on 5' spacing, they are much less rigid and lighter than the building you are talking about.
/ Carport Weight #43
i believe that we are talking about 2.5" tube uprights on 5' spacing. these things have and need a lot of give to them and i would be afraid of welding (in some spots) where i know that they react very well to screws, and yes there is also the galv to worry about while welding. IMO better to use screws but your welding skills are probably much better than my mud dobber welds.
/ Carport Weight #44
Now I'm going to measure my spacing lol anyways lots of options some I agree with more than others if the op chooses one. The execution of method will be worthwhile to follow for me anyway.
/ Carport Weight #45
You should realize there are ways to stabilize the the building enough to raise it up and ways to secure it to a flatbed trailer.
/ Carport Weight #46
No matter what causes the actual motion of the move, you are going to have to have a skid or framework that supports all the vertical uprights on its standard/correct geometry, or its going to be a pile of tinfoil.... Once you have a skid or platforn the rest is simple....
Check YOUTUBE for videos of house movers...
/ Carport Weight
It’s actually 2.5” tubing on 6’ centers. In SC we don’t have snow loading issues.
/ Carport Weight #48
/ Carport Weight #53
yes i do but depending on the terrain by the time you do all of that it could have been skidded into place and beers drank. note that the last part is the most important.
/ Carport Weight
We ended up just taking it down.
Here’s the replacement version.
MF GC2300 fel replaced
BUSH HOG RD-600 ROLLOVER BOX BLADE (A64280)
BUSH HOG RD-600...
John Deere Hubs and Spacers (A64119)
John Deere Hubs...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
2025 Swict 66in Bucket Skid Steer Attachment (A61572)
2025 Swict 66in...
2007 Cadillac DTS Sedan (A61574)
2007 Cadillac DTS...
