Broken FL 3615 Loader
   / Broken FL 3615 Loader #11
Ive seen several broke ones. Weld it up and continue on with life.
this....is probably....a good life choice. friggin make it work and get it done.
   / Broken FL 3615 Loader #12
If you plate it, weld one on the other side so it looks like it came that way.
   / Broken FL 3615 Loader #14
Drill a hole at the end of the crack to stop the crack from spreading further before you weld it.
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A51039)
2012 Freightliner...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2001 VOLVO A35D WATER TRUCK (A51242)
2001 VOLVO A35D...
2011 CATERPILLAR D9T HI-TRACK CRAWLER DOZER (A51242)
2011 CATERPILLAR...
2015 MACK GU713 DAYCAB (INOPERABLE) (A50854)
2015 MACK GU713...
2011 Ford Transit Connect XLT (A50323)
2011 Ford Transit...
