Broken FL 3615 Loader
/ Broken FL 3615 Loader #1
matt1490
Case 1490
Does anyone have heard of a fl 3615 loader cracking? My buddy has one that has severely cracked around where hoses come out of bottem of loader
Pictures of loader
/ Broken FL 3615 Loader #3
Pretty unusual. Most tractors/loaders do not have the strength of hydraulic force to break a loader like that. When they do break the ones I have seen usually break at welds and usually where some unusual leverage or bending was applied. I'm NOT a loader expert by any stretch but I've not seen this before.
I see where these FL series loaders are pre-stressed and the beams are narrower than traditional loaders. Claims are that they are stronger -- your buddy's experience brings that into question. I would think the MF regional rep needs to be contacted immediately and shown this break. And asked if there are others reported. Pretty serious stuff.
/ Broken FL 3615 Loader #4
Wow, That is not good. I have cracked loader frames usually from lifting uneven loads or doing something repeatedly to twist to frame. I was pushing silage in a pit which cracked the frame on an older deere.
This tractor is used to push snow
Tractor is 3 years old dealer was contacted and pictures were sent to massey
/ Broken FL 3615 Loader #8
Pushing snow is hard on a front end loader hitting obstacles and whatnot looks like you're out of warranty so weld/fish plate it up and be on your way
/ Broken FL 3615 Loader #10
Ive seen several broke ones. Weld it up and continue on with life.
/ Broken FL 3615 Loader #11
this....is probably....a good life choice. friggin make it work and get it done.
/ Broken FL 3615 Loader #12
If you plate it, weld one on the other side so it looks like it came that way.
/ Broken FL 3615 Loader #14
Drill a hole at the end of the crack to stop the crack from spreading further before you weld it.
