Error correction
/ Error correction #1
Torvy
Super Member
North East Texas
TYM T574H
I figured since there is not a logging or timber section on TBN, this would be the best place for advice on how to fix my mistake.
I had a 12 year old+/- loblolly pine die in my little forest. I missed a bit on where it would drop and it got hung up. It is not close to any building, roads, etc. I left it alone for a couple of weeks (hoping wind would bring it down). The trunk is 100% off of the stump, but it is still 'standing' with about a 15%-20% lean.
My current thought is to hook up a logging rope/chain to the lower end and (from 50+ ft away) pull the trunk out from under the tree. Once it is down, I can easily break it down to manageable size. I estimate it is about 25-30 ft tall and around 1400-1600 lbs. I down like the potential risk of it falling at the wrong time and injuring anyone or anything.
I am admittedly inexperienced in this aspect to tree work. Any thoughts, ideas and suggestions are welcome.
/ Error correction #2
I've done what you're talking about, usually I redirect it so if it suddenly shoots out along the ground I'm not in the line of fire. More typically the butt digs into the soil a crap ton and makes a big furrow or they flop all the way back over opposite from where they were leaning. Either way you want to be well away from it.
/ Error correction
Thanks. Any recommendations on rope/cable? It is stuff I am going to need in the near future anyway as we are only a few months away from moving out there permanently.
For this one, I am planning to use the Tundra to pull from a distance about 2x the height of the tree.
What do you use for redirect? I could pivot on a Sweet Gum that I will eventually remove anyway. Not sure of that is advisable or better techniques exist.
/ Error correction #4
I don't know about "redirecting" it, but I have done it with steel cable around the trunk (something that wont fray when dragging the butt thru the dirt). Then a long rope about four times the height of the tree....attached to my F-250.
Cheers,
Mike
/ Error correction #5
I've got a 150' "bull line" I picked up a while back I use for all the tree chores aside from dragging them through the woods, works great. I usually redirect with a 4'x2" strap and a gigantic shackle (Think it's 1 1/4 diameter?).
More typical of my use for the bull line, this was tornado damage. The stump had about 20' of tree on it I had to cut to get at this top portion that got ripped off, this was actually about 4 hrs into the cleanup project finally getting to where I could access the widowmaker.
/ Error correction
That looks like another project I have on my list. I have one that broke in half. Not sure if lightning or rot (thinking rot, though). I guess I have some shopping to do since school is out due to the weather.
/ Error correction #7
Cheers,
Mike
You have some holy grail fire wood there...
/ Error correction #8
I have had to do this many times , If the trunk is not dug in deep giving it a tug will usually drop it, If using a strap get a good one, If it snaps it can send the hook your direction,
/ Error correction #9
I've used a winch cable from HF. It's about the least expensive cable you'll find. You'll need cable clamps and a ferrule to form an eye to pull on. Use chains to attach the cable to the tree or to extend the reach.
If the tree would come free easier if it rolled one direction or the other, you can attach your chain so that pulling on it will make the tree roll a bit first before it starts pulling the butt.
A way to do this without pulling is to cut the trunk in sections. You need to make a cut on the top side first then cut from the bottom. This method gradually stands the tree up which might be a problem for controlling the falling direction.
When you redirect off a tree that you want to keep, you need to use a wide strap to hold the pulley. If you run a cable or chain around the tree it will rip the bark up. Even the strap can damage the bark if it slides on the tree and the bark is thin.
/ Error correction #11
Good advice but recovery straps without hooks or chains are advisable.
/ Error correction #12
I always throw an old blanket on the rope or chain, about halfway up. This keeps the rope/chain form coming back at you if it should break. A snapping rope/chain will hurt you.
/ Error correction #13
Do NOT use a "Recovery" strap for this. Recovery straps are designed to have a good bit of elasticity, which is exactly what you don't want when pulling on a tree. If it should break, or something lets go, that elasticity acts like a sling shot.
/ Error correction #14
Torvy -
Way too many variables to go from a text description. I hesitate to give advice on hung trees unless I'm there in person looking at it, but at least some photos would be helpful. Some hat show how the butt is resting, some showing the whole tree and how it is hung up, and somethign showing the surroundings would be helpful.
/ Error correction #15
this is exactly correct, get the chain low as possible. If it was a bigger tree, put a pulley up 10 feet in a large near by tree and pull through the pulley to lift the base. As small as it is, if there is nothing near by to break, put the chain low and stay as far away as possible. try and look around that there is not a near by tree you might domino on yourself:)
Best,
ed
/ Error correction
Torvy -
Alright. We were out there today and I snapped a shot.
/ Error correction #18
Buy a choker cable. It’s what professionals use and with your forested land, you will get plenty of use skidding firewood. Fasten to the tractor drawbar, not 3ph.
/ Error correction
Thanks. I did know enough to use the drawbar. I've got to get some good logging rope, too. Skidding should be limited to short distances, just to get clear enough to cut to size and haul away on the trailer. This particular tree just needs to be down. It is only a short distance to the homestead from there.
/ Error correction #20
Looking at that picture if you give it a good yank to the left, as seen, I think it should roll off and fall.
You're thinning project looks a whole lot like mine, what a pain.
JOHN DEERE 1520 - 15' GRAIN DRILL (A63291)
JOHN DEERE 1520 -...
2016 Ford F650 Ext Cab Flatbed Truck (A62613)
2016 Ford F650 Ext...
2015 Ford Escape SUV (A61574)
2015 Ford Escape...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
2021 Exmark Lazer Z 60in. Commercial Zero Turn Mower (A61572)
2021 Exmark Lazer...
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
