Bearing removal
/ Bearing removal #41
JimRB, Thanks for posting this video. I found it fascinating to watch a machinist do their very exacting work! Way out of my league but very informative, interesting and educational!
/ Bearing removal #42
I have 2017 branson 3520cx tractor...the bearing on front axle is shot on piinion shaft i was able to seal out...now bearing stuck on shaft...Any suggestions how to get it out..thank u
The old way to remove a bearing off a shaft was to put the bearing (with axle) on an anvil. Use a good chisel on the top of the bearing....Two or three good hits and the bearing slides right off....
/ Bearing removal
Thank all kindly im looking at speedy sleeve
/ Bearing removal
Omg it goes from bad to worse lol got pinion out..now chipped ring gear...i got new pinion and ring gear on way..anyone know if big job to change ring gear...by a old 80 yr old farmer..thanks u guys for help.chip on ring gear not bad wonder get by not changing it
/ Bearing removal #45
Pictures of course would help. I would change the ring gear with the pinion anyway. Kind of want those things to wear together. The service manual somewhat shows you what is involved but you do have to jack the front of the tractor up and support it. You will have to take the front axle down from the right side to get the assembly out. These will be heavy and you do have to separate the tie rod end from the steering knuckle.
But you seem to be able to get around very well at 80 so for you it may not be an issue. Biggest thing is if you are not comfortable you can do it safely then get some help. It is not worth getting hurt over.
/ Bearing removal #46
If the ring gear isn't missing a tooth, I would run it. Hang on to the new ones and send back. On the pinion you can use speedy sleeve, or have it bronzed at a machine shop. I'm not above hitting that gouge with a welder and filing it down smooth. But really I'd get a double lipped seal, polish the shaft and run it as it is. Its all slow moving parts anyway. My Papaw drove an old truck for years. Somehow, maybe someone worked on it and forgot to fill the rear with gear oil. It squalled bad after that. He packed it full of bananas and drove it years after that.
/ Bearing removal
I got axle out on bench parts be here monday.is there any gaskets or seals i need to buy to replace ting gear...thank u again for assistance.
/ Bearing removal #48
Should only be seals or gaskets where the axle housing separated. Internally would not have any.
/ Bearing removal #49
Pinions and ring gears are always replaced in pairs as they are finish ground after hardening to match each other. If the ring gear has a small chip in it I wouldn't worry about it. Just smooth the edges of the chip off and put it back together.
If you install a new ring and pinion you need to set the ring gear sideways relative to the pinion and the pinion needs to be set in and out relative to the ring gear. I've done it but it's an involved process. If you get to that point it would be advisable to have the help of someone who has the measuring tools and the know how.
/ Bearing removal #50
Making any headway?
/ Bearing removal #51
My uncle redid the spindles on a small catapillar
and he used nickel silver welding rods to build
them up and then ground them to spec's
I used silfos to solder a/c copper fittings and I
didn't have any solder so used silfos to solder
some heavy copper wires and had a piece that
was sticking out and I could not cut it off with
wire cutters had to grind it off, it sure went up in
price $4 a stick and higher???
willy
/ Bearing removal
Making any headway?
Well got axle out ring gear got couple chips..branson say two diff ring gears..one with dowl pin one without...they dont seem to know which one i have. so going tear down axle..and determine..one i will need new diff..other i dont....tractor be death of me Thank u
/ Bearing removal #53
Stay with it. You will get there.
/ Bearing removal
Well took two months but i got it done..new pinion and ring installed..no leaks..Wish to thank All that assisted me..thank u All
/ Bearing removal #55
Great Job! Glad you got it done!
/ Bearing removal
Question..how do u keep diff lock in...im plowing snow thats its manual shift trans with clutch.
/ Bearing removal #57
You have to hold the lever down with your foot.
/ Bearing removal
Well thats crazy how u suppose hold down and press clutch..🤣 but tks for reply
/ Bearing removal #59
You press it with your right heel. Isn't the clutch pedal on the left and the diff lock on the right on your tractor?
CAT Chassis Only (A59076)
CAT Chassis Only...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2022 Case SV280B (A62177)
2022 Case SV280B...
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
2008 IC Corporation PB105 School Bus (A60352)
2008 IC...
