Carport Weight
/ Carport Weight #1
dieselscout80
Elite Member
South Carolina
New Holland TC45DA
All, question what do you think this carport weighs?
I want to move it and I am thinking about moving it without taking it apart.
Its 24’x24’ and post’s are 9’ tall. The posts are 2.5” square.
/ Carport Weight #2
I'd look on line for a similar carport to see what the shipping weight is.
I don't think weight will be your issue. The issue is that moving it will cause the frame to flex possibly tearing the roof around the fasteners unless you can figure out a way to stabilize it and go very slowly over a short distance.
/ Carport Weight #3
I'd use 8 6" C clamps, 4-12' 2x4's and 7 strong buddies, and you making a guy on each leg.
/ Carport Weight #4
I think this is spot on. I have the same carport. It used to flex in the wind before I welded steel gussets to the corners to stop that. But the roof sheeting started to tear around some of the screws because of the movement. It’s a pain but I think the best option is to remove the roof panels, then move the carport. It will be a lot lighter and easier to move also and no chance of structural damage.
/ Carport Weight #5
When they build those sheds, it is all loaded on a 16' trailer behind a half ton truck. Bulk is your problem, not weight. So if you have something big enough to put it on, it will handle the weight. Haul it sideways and put the bottom runners on a trailer. Tie it down, keep it tied down at all times. Wind will easily roll it into a ball of scrap metal. Neighbor boy had one, oh yeah I'm gonna tie it down. Week later it was over in his neighbors pasture, crumpled up like a stomped can. Never touched the fence.
/ Carport Weight #8
Build a BIG skid and anchor it to skid and tow it by the skid...
Those carports aren’t that hard to disassemble. I might consider putting a piece of lumber at both ends for a spreader to keep the legs spaced apart and drag it but much beyond that you’d be faster to take it apart.
/ Carport Weight #9
Yes, and I am pretty sure that the roofing panels will get widened or torn at the screws fastener locations by moving. Then it leaks everywhere.
/ Carport Weight #10
Have a 12x20 carport 8' walls moved a half dozen times around my property still standing no leaks very minor damage, I also moved a 20x24 12' high greenhouse off my polebarn still standing I did reinforce it with some steel extensively. Anyways I think if you can get two tractors lift it slightly on the base rails in the direction your dragging choke it under the base rail and a upright, and communicate well with the other operator you should be good. I can take pics of various reinforcement I did on green house before moving if you want. The 12' wide carport I didn't put extra reinforcement in it and used one tractor when moving. The green house I used one skid steer and a tractor and it was a straight pull. Good luck
/ Carport Weight #12
I disagree. Wife and I built the frame then hired a contractor to do the roof. 6 hours for 2 guys, ladders, million screws, seals at all the joints, edge trim. To disassemble, you will need to mark all the sheets.
This is a 20'x24x8. After the roof, then we did both sides and one end. It took our old bones several days to do what we did. I would build another one at the new location before I would try to move it.
/ Carport Weight #13
I moved ours with a forklift and some very wide lumber, they weigh hardly anything so watch the wind!
/ Carport Weight #14
Here's how someone on OTT did it:
/ Carport Weight #15
Interesting....but personally I'd have used a heck of a lot more material to cross brace the carport before trying to move it.
/ Carport Weight
Kinda how I was thinking, but with one tract in the middle of the carport lifting from both opposite ends from how they did it.
/ Carport Weight #17
Diagonal cross bracing in the form of an X would be more resistant to flexing that could cause tearing in the roof panels.
/ Carport Weight #18
We’re only moving it about 100 yards.
We bought an 18 x 30 kit. had it rated for 55lb snow load and 150 MPH winds. It came in two pacs. The sheetmetal roofing was around 1200lb and the framing pac was just over 1700 lb IIRC
/ Carport Weight #19
#7 picture of carport I've moved 1/2 doz times at least a few hundred feet in total. #1 and up are pics of green house I moved off the gable end of barn no pics of actually moving it out of learned mistakes I put phone and camera down when operating equipment lol anyways I know it's a lot heavier than any carport, had to cut lower uprights cause they were embedded in concrete, fortunately I had a lot of heavy gauge rusted repurposed angle iron lying around so I welded it around base and to cut uprights I also welded a piece of angle from the uprights below girder and welded srap angle diagonals in pic I removed center base piece I attached. To bottom of uprights left diagonals in place. One thing I can tell you is when moving it and it starts digging in ground stop immediately. Also when I moved green house I felt it may not make it but was ok if move failed and it came down cause other option was to tear I to down anyway I replaced green house on polebarn with another more usable structure. Any specific questions feel free to ask as my pics I took are snow covered and my explanation is probably lacking for some.
2005 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A66736)
2005 Mack CH613...
2016 KUBOTA SVL75-2 SKID STEER (A65056)
2016 KUBOTA...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
2017 Autocar Xpeditor T/A EZ-Pack 40yd. Front Loader Garbage Truck (A66736)
2017 Autocar...
ROOF RACK (A68842)
ROOF RACK (A68842)
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
