Stone dust for traction on ice
   / Stone dust for traction on ice #11
heck give it try and give us update.
If it's a fine dust not sure how much traction you shall get...need little more grit.
I dunno...I use woodstove ash on ice here and it works better than sand. It's about as fine as it gets. Downside is it tracks more than sand too. We remove our shoes before coming in the house so it's not as big a deal.
   / Stone dust for traction on ice #12
Usually there’s 100lb bags of coarse sand available at your local masonry supply. They are manageable and can store for a few years before the bags give out.
Dirt cheap, too.
   / Stone dust for traction on ice #13
Might make a difference of what kind of stone that's available. We only have limestone around here, which is famous for retaining moisture and clumping when cold enough. Haulers warn about spreading #53's* when it's freezing because of clumping.
* part gravel, part limestone dust, for packing
   / Stone dust for traction on ice #14
I had a pile of limestone dust, on ice it was like white mud and did not help much. I'd think crushed stone "11's" would be much better, about the size of small pea gravel
   / Stone dust for traction on ice #15
I use pit run sand, I get a triaxle load every couple of years, it has some salt mixed into it to slow down the freezing in the pile.
This year when I got my load I added 500 pounds of more salt to the top and mixed it in a bit.
I also use coal ash most years to as a good way to use the ash.
The last 3-4 sacks of salt spread out
mixed into the top layer and all pushed back
Tarped and ready to be uncovered and loaded into the sander.
sander ready to be loaded and spread
Dirt cheap, too.
Do they freeze up in winter?
   / Stone dust for traction on ice #17
Lou, very nice work.
   / Stone dust for traction on ice #18
I have not had that problem so long as the buyer or the supply house doesn’t leave them outside.
Typically when I did masonry work, the masons didnt want it to freeze, either. My supplier stacked the bags under roof and off the bare ground.
I kept the bags in my garages along with 80lb bags of rock salt. I would load my spreader with one bag of salt, then one bag of sand, mixing along the way, until the spreader was full.
   / Stone dust for traction on ice #19
I think it will work, I use North Thompson River sand, well, what I do is in the fall when the water level is low, I take 5 gallon buckets and a shovel down to the sand bar, load up a few, bring them home, then use it on my icy gravel driveway. As long as the ice is not to hard, it works incredibly well to prevent slips or falls. sprinkle the sand on, traction gained.
I have thought about heating the sand slightly to "melt" it into harder ice, but, have not tried it yet.
I'm getting different opinions on adding salt. Some people say salt increase moisture.. wondering what is true
2018 HONDA RECON 250 4-WHEELER (A51247)
2018 HONDA RECON...
Wood Cowboy Statue (A53316)
Wood Cowboy Statue...
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A55788)
2012 Dodge Ram...
Golf Cart (A55853)
Golf Cart (A55853)
New Quick Attach Hay Spear (A54865)
New Quick Attach...
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A56129)
2007 POWERSCREEN...
