I'm curious if anyone out there can point me in the direction of a good 3 point tiller that can handle red clay and go a good 8" deep
Thank you
Most likely either the WD-45 Diesel or John Deere 5400.What tractor do you propose to power the tiller?
That may be a little overkill for my needs. This will pretty much only be to prep gardens in the spring.Every model from Northwest Tillers can handle red clay and churn earth 8" deep.
Tiller widths from 48".
Full Till - Northwest Tillers
Full Till options by Northwest Tillers are the toughest around. Super heavy tillers that stay in the ground and get the job done.nwtiller.com
How about a mulcher/tiller that will last you two generations? This extremely heavy-duty and versatile tool can prepare any type of soil, including heavy clay, loam and river rock to breaking virgin ground, cutting sod, alfalfa and pasture, for seeding in just ONE PASS. Custom manufacturing for each farmer’s needs with the ability to incorporate chemicals, fertilizer, green manure or crop residues, Northwest Tillers help produce healthier soil for healthier crops and reduces fuel expenses, labor cost, and soil erosion.
Yeah, HST is a must have to be able to creep slow enough.For 25 years I've been running a 6' KingKutter in heavy clay with 30 pto hp. Breaking sod is slow go, but I have HST and can creep along. It covers the rear tires, that's what I wanted. I don't regret going with a 6' tiller.
Not really. My creep gears can drop my travelling speed down less than 1/10th mile [per hour with 100% of the power going to the PTO.Yeah, HST is a must have to be able to creep slow enough.
One thing I learned about auction tillers long ago is check the time length b/4 bidding.From the sounds of your use you'd be crazy to pay new prices, either get a used/auction thing or hire someone to do the initial ground breaking for you and get something lighter.
IMO, shop local auctions.
If you've got HST, don't be afraid to go wide; creep and get it done in a couple passes.
Auction tiller may be no-name from china like mine but I use it a few times in a year and this thing is built heavier than my tractor (and my tractor's one of the more heavily built ones, too) so the chances of it breaking under my use is slim to nil.
| John Deere 5400 Power | |
| Engine (gross): | 68.4 hp 51.0 kW |
| PTO (claimed): | 60 hp 44.7 kW |
| Drawbar (tested): | 52.61 hp 39.2 kW |
| PTO (tested): | 62.56 hp 46.7 kW |
| John Deere 5400 Weight | |
| 2WD ROPS Shipping: | 4560 lbs 2068 kg |
| 4WD ROPS Shipping: | 5070 lbs 2299 kg |
| 2WD Cab Shipping: | 5460 lbs 2476 kg |
| 4WD Cab Shipping: | 5970 lbs 2707 kg |
| 4WD ROPS Operating: | 5118 lbs |
Did you mean to put 15? I think 5 PTO HP per foot is the usual rule of thumb.15 pto horses per foot of width.
