6' Tiller
/ 6' Tiller #1
JustinE
I'm curious if anyone out there can point me in the direction of a good 3 point tiller that can handle red clay and go a good 8" deep
Thank you
/ 6' Tiller #2
I took the skids off my King Kutter tiller and till with it buried.
/ 6' Tiller #4
What tractor do you propose to power the tiller?
/ 6' Tiller #5
Thank you
Every model from Northwest Tillers can handle red clay and churn earth 8" deep.
Tiller widths from 48".
How about a mulcher/tiller that will last you two generations? This extremely heavy-duty and versatile tool can prepare any type of soil, including heavy clay, loam and river rock to breaking virgin ground, cutting sod, alfalfa and pasture, for seeding in just ONE PASS. Custom manufacturing for each farmer’s needs with the ability to incorporate chemicals, fertilizer, green manure or crop residues, Northwest Tillers help produce healthier soil for healthier crops and reduces fuel expenses, labor cost, and soil erosion.
/ 6' Tiller #6
For 25 years I've been running a 6' KingKutter in heavy clay with 30 pto hp. Breaking sod is slow go, but I have HST and can creep along. It covers the rear tires, that's what I wanted. I don't regret going with a 6' tiller.
/ 6' Tiller
That may be a little overkill for my needs. This will pretty much only be to prep gardens in the spring.
/ 6' Tiller #9
Yeah, HST is a must have to be able to creep slow enough.
/ 6' Tiller #10
From the sounds of your use you'd be crazy to pay new prices, either get a used/auction thing or hire someone to do the initial ground breaking for you and get something lighter.
IMO, shop local auctions.
If you've got HST, don't be afraid to go wide; creep and get it done in a couple passes.
Auction tiller may be no-name from china like mine but I use it a few times in a year and this thing is built heavier than my tractor (and my tractor's one of the more heavily built ones, too) so the chances of it breaking under my use is slim to nil.
/ 6' Tiller #11
I don't know how it is around your area but here - used implements are scarce to nonexistent.
/ 6' Tiller #12
Most likely either the WD-45 Diesel or John Deere 5400.
I think your JD will have enough grunt for this. I've been looking at the Woodmaxx. If you're going to be breaking new ground frequently, maybe look at the EA heavy duty ones.
/ 6' Tiller
As far as used prices in my area, there's a lot of the , "I know what I've got" mentality. Some of the things they're trying to sell are older than I am and almost as much as new.
/ 6' Tiller #14
Not really. My creep gears can drop my travelling speed down less than 1/10th mile [per hour with 100% of the power going to the PTO.
I use mine for planting produce all the time, well I don't, the guy down the road does. You can get out and eat your lunch and get back in, it's that slow. For me at least, any HST is a waste of power.
/ 6' Tiller #15
One thing I learned about auction tillers long ago is check the time length b/4 bidding.
/ 6' Tiller #16
2 years ago I got a price of $17k to put in a new lawn. wtf??? Although I am still working, I work from home. Simple solution - I bought a good tiller from EA. It was a Simca (Italian) with reverse rotation. They don't show it available on THEIR SITE but it was a 66" beast.
Glyphosate, box blade to remove the big rocks and the Simca Phoenix T10-GE did an awesome job. Not needing it anymore I sold it to a guy from RI. I lost a few hundred $$, he got a great deal on a like new tiller and I have a new lawn that ended up costing me my labor and less than $2500
/ 6' Tiller #17
I have a wood's 72" tiller and after one pass
the ground is ready to plant!
willy
/ 6' Tiller #18
John Deere 5400​
John Deere 5400 Power
Engine (gross):68.4 hp
51.0 kW
PTO (claimed):60 hp
44.7 kW
Drawbar (tested):52.61 hp
39.2 kW
PTO (tested):62.56 hp
46.7 kW
John Deere 5400 Weight
2WD ROPS Shipping:4560 lbs
2068 kg
4WD ROPS Shipping:5070 lbs
2299 kg
2WD Cab Shipping:5460 lbs
2476 kg
4WD Cab Shipping:5970 lbs
2707 kg
4WD ROPS Operating:5118 lbs
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A63689)
2019 Takeuchi TL8...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
2010 Dodge Grand Caravan Van (A61574)
2010 Dodge Grand...
2015 Ford Explorer AWD SUV (A61574)
2015 Ford Explorer...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A65054)
2016 INTERNATIONAL...
