Hay Dude
Epic Contributor
- Joined
- Aug 28, 2012
- Messages
- 25,745
- Location
- A Hay Field along the PA/DE border
- Tractor
- Challenger MT655E, Massey Ferguson 7495, Challenger MT555D, Challenger MT535B Krone 4x4 XC baler, 2-Kubota ZD1211’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mower, NH wheel rak
My Challenger has a typical plastic roof shell. Previous owner installed a home-brewed light bar bracket. Looks/works fine except one thing: It makes the tractor about 10’-2” high. I am storing it in a barn with a 10’ door opening for snowplowing season. Figures….
I removed the strobe light from the light bar and leave light bar in place the tractor is about 9’-10” high, so now it fits, but no strobe for snowplowing. If I stuck strobe directly to roof plastic, it would be about 9’11” high-it’ll just squeak through.
I’d like to fasten the strobe directly to the roof plastic to lower my overall height & retain use of strobe. The strobe, normally bolted, has 2 rubber mounting discs about 3” diameter. I presume they are shock absorbing and also leave an opening for the power wire.
I can’t use bolts or drill the roof.
Would large pieces of velcro stuck to the bottom of rubber discs and on top of roof plastic work? I don’t know if velcro adhesive sticks to rubber? It sticks to plastic very well. The power wire could act as a tether if it’s ripped off by a branch.
Or, what would be alternative suggestions would be better to stick directly to roof plastic? Gotta hold pretty good.
