How remove bolts-ct2025 brush guard?
/ How remove bolts-ct2025 brush guard? #1
wisconsitom
Bobcat ct2025 HST
Hi all. Wishing to remove factory brush guard to add/ weld expanded metal. Guard is secured by 4 bolts. Bolts have no nuts and deadend in frame. These bolts are very tight. I put all I dared to on them, working from below with great leverage, and could not budge. I mean, I was pulling so hard on that wrench that had it slipped or had one of these bolts started to turn, I might've broken some ribs. But no-go. Any suggestions,?
/ How remove bolts-ct2025 brush guard? #2
Heat to cherry and crank them off, or just break or saw or grind them off. Nuts & bolts are cheap. Einstein proved that Time is Money. (That would be Herb Einstein).
/ How remove bolts-ct2025 brush guard? #3
I would highly recommend you invest in a battery, or air, impact wrench.
Got a couple battery units, suppose we can give em a try. I just want to be assured these bolts are meant to be removed and that they aren't left-hand thread or something weird like that. Thanks. Yeah we're looking at air impact unit for up at that shop. Maybe sooner than later.
/ How remove bolts-ct2025 brush guard? #5
After giving them a soak in penitrating and alowing a bit of time to work, I go for an impact wrench, but if that is not enough I go for my old fashion impact driver you whack with a big hammer. If that doesn't do it you finish up with a bolt in two halves. Then it's plan B
/ How remove bolts-ct2025 brush guard? #6
I have taken mine off with a battery milwaukee impact wrench. I splurged a bit and got the one off ebay with the bobcat laser cut into it. Looks better than factory and fit well. Just drill 2 holes bolts onto the factory guard.
Thanks all. Will try battery impacts when I'm back up there. Wouldn't mind not sizzling that paint off where bolts attach if I don't have to.
I like those Bobcat (and Kioti) grills they offer, but we're already down the road of making our own.
/ How remove bolts-ct2025 brush guard? #9
Bought or built, they're an absolute must; it only takes one rogue pole, stick, branch, etc., to really ruin a day.
/ How remove bolts-ct2025 brush guard? #10
Any chance you still have a link? I made one but I'm not entirely happy with it (other than price).
/ How remove bolts-ct2025 brush guard? #11
You can purchase them on eBay, but you can also order them right from the manufacturer.
I'm extremely happy with mine.
/ How remove bolts-ct2025 brush guard? #12
Very nice. Thanks!
Pretty nice. We got our home-built all painted and ready to bolt back on.
1995 John Deere 7400 (A60462)
1995 John Deere...
2022 CORMIDI C85 STAND-ON MINI DUMPER (A62129)
2022 CORMIDI C85...
2019 KUBOTA SIDEKICK RTV-XG850 (A62130)
2019 KUBOTA...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
