Neoprene Rubber gluing?
   / Neoprene Rubber gluing? #1
ArlyA
Super Star Member
Houghton MI (the Lake Superior snow belt) USA
Outlander1000 6x6, Ego lawn mower and shopping for tractor
I've got some Neoprene Rubber pieces I need to glue together. This is not foam but solid belting. According to the internet, many contact cements are suppose to work on it but I've tried 2 and both didn't do much for its attachment. Just for fun I also tried rubber vulcanizing chemical, vinyl glue and muti use PVC type cement. Not! I also tried silicone type glue but it takes 24 hours to set so I'm not yet able to try pull it apart. I also emailed the retailer and asked them what to glue it with. :unsure:
   / Neoprene Rubber gluing? #2
Try Super glue?
   / Neoprene Rubber gluing? #3
I would reach out to a roofing company that does membrane roofs, they probably have just the thing.
   / Neoprene Rubber gluing? #6
A very clean surface, try using rubbing alcohol liberally to clean well, and applying lots of pressure for atleast a few hrs on what your trying to glue, it's worked for me most of the time.
I have cleaned with alcohol between attemps and changed out my cleaning rags..... For the silicone type glue I appiled tonight I rouged it up via sand paper before the attempt..
   / Neoprene Rubber gluing? #8
Find out how they seal pond liners together? :)
   / Neoprene Rubber gluing? #9
Is it possible to setup clamps using blocking backers of some type to apply lots of pressure to what your trying to glue?
Well it is but I'm now just trying it on little chunks to see if something works. I do put my drill index on it for some pressure but the pieces are only about 2 x 2" in size.
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
New/Unused Quick Attach Seeder (A54865)
New/Unused Quick...
2012 Big Tex 14ET-20BK 20ft T/A Flatbed Trailer (A55852)
2012 Big Tex...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
HYDRAULIC MOTOR AND PUMP ON A SKID (A55745)
HYDRAULIC MOTOR...
2021 BOBCAT S740 SKID STEER (A52707)
2021 BOBCAT S740...
