Yanmar 2200 Drowned??
/ Yanmar 2200 Drowned?? #12
I would turn the motor over by hand, either with a wrench on the crankshaft or a screwdriver on the flywheel to make sure it isn't hydro locked and then change the oil. Once you get it running, get it up to temp, then change the oil again!
David from jax
What can I say? I have been a lurker. I love reading all the posts on TBN but rarely have anything worth adding. My advice is worth what I charge for it - bupkis!
Thanks to everyone for the good information. I'll be opening this can of worms when I get a free weekend and will give you a report on what I find.
John.C.
/ Yanmar 2200 Drowned?? #15
Welcome to the posting world at TBN! (And a great quote by the way.)
I hope that this turns out to be simple for you.
All the best,
Peter
/ Yanmar 2200 Drowned?? #16
John.C.
My thoughts are, if there is any chance of water in the cylinders, I would make it a very high priority! It won't take long for water on those unprotected cylinder walls to make a mess out of a good engine! Even if it has been a while since the roof collapsed, it might make a difference to shorten the time by as much as possible.
David from jax
AGT Industrial ATK-B1000 2 Post Car Lift (A60463)
AGT Industrial...
2024 Case IH Farmall 75A (A60462)
2024 Case IH...
2014 RAM 2500 (INOPERABLE) (A58214)
2014 RAM 2500...
gps trailers (A56859)
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
2009 MULTIQUIP 25KW GENERATOR (A58214)
2009 MULTIQUIP...
