Generators, sizes and fuel options?
   / Generators, sizes and fuel options? #81
I just skimmed the thread, hopefully not too much repeat here.
My area gets multiple-days power outages in the summer (because of <10% humidity + decent winds = power line fires) - hopefully less as they update power lines and better maintain the ROW's - and short to medium length outages in the winter (last January, out power went out for a day, but some friends a few miles away lost power for three weeks because of the same storm).
The biggest problem with an automatic transfer switch is that it's going to use up all of your fuel in a hurry. The typical generator is not exactly sipping fuel even at idle, unless you really shell out and get a diesel. The automatic transfer switch will power up that generator at 2AM when the power fails and though you've got 300W draw in the house, you're still using 1/2gph. This is fine, if you've got 250-300 gallons available and you're only expecting to have a couple days failure. A week? It's gone and you're out of power.
For DIY-ish people, my strong suggestion is a manual transfer switch for specific circuits - water well, a couple lights, furnace/heat pump, maybe something else. You connect your generator and run it manually and it will last a long time, because you turn the damn thing off as soon as you don't really have to have power.
We've had that setup, and I ran this place during an extended power outage when there was a (very) nearby forest fire and kept our fridge and deep freeze going, plus intermittent use of the well when we came back, with a 3.5kW generator - it wasn't on all the time; we just ran it occasionally to re-chill the stuff or when we really needed to flush. It's a hassle, but a 3.5kW generator barely uses any fuel this way.
I've put a lot of thought into doing a whole-house genset (and I plan to do it), but my situation is a bit different. I've got solar, plus batteries, and the whole house automatically swaps to battery already in a grid failure.
I can set up a generator as input to this system, so that it can recharge the batteries for winter use. With this, and judicious use of electricity in the house, I figure I can weather a 30-day power grid failure with zero solar recharge, which is really unlikely to happen (on a really dark stormy day I get next to no solar, but on a bright overcast winter day there's almost enough for my minimum use).
The way this works is - the system is programmed to fire up the generator when the batteries fall to 30%, and the generator will run at full load - where it's the most fuel efficient - until the batteries are at about 80%, and then turn off. The vast majority of time, the generator isn't running (blessed silence) as the house uses the battery, and it when it does run you get the most from it as possible (you can also set lock-out time periods where the generator won't run even if the battery is this low, unless it gets to another lower point - for instance I'd set the lock-out from 9pm-6am with a force turn-on at 20%, to keep things quiet at night).
   / Generators, sizes and fuel options? #82
+1 on the energy and duration advantages of manually controlling loads.
Not being able to integrate a generator is my only regret on my solar + battery system. I went with AC batteries, and there really isn't a great way to integrate a generator.
Win some, lose some. It works great normally, but if the power goes out in the predictEd bomb cyclone, and it stays overcast, I know that I will be reaching for my generator(s).
All the best,
Peter
   / Generators, sizes and fuel options? #83
<snip>
<snip>
Good point.
How difficult would it be to wire the system so one could put the automatic transfer switch on some sort of delay, so it only came on after a set period of no power?
MOST of my outages have been temporary. In the last 40 years I've only experienced maybe 5 outages of several hours or more.
   / Generators, sizes and fuel options? #84
they have a delay, but its only for so many minutes.. i think like 40 minutes max as i recall. on mine, if power dumps at 2 am, gen will start. i have to physically go out to shut it down. you can design a mcgyver's system to shut it down from indoors, but you need to first disconnect the load, let engine run for a few minutes unloaded, then shut down generator. cant be a simple switch. would require relays and contactors. Ive actually thought of doing something along these lines, but always too busy to mess with it. someday i will.
personally, i dont find it much of an issue to go and shut it down. if it was -20 outside, id just let it run.
So I have spent time researching and adding up my load and I think I am over sizing my inverter. I have confirmed my load. Well pump is 3/4 Hp on 240v 20 amp for 1100 watts startup. My fridge is 9.5 amp startup for 1000 watts. My indoor boiler is negligible (Pilot light with propane) hot water is none(indirect water heater). Those just use power for zone valves and turning on the propane, so let’s say 100 watts total. I have 3 taco 007 pumps, total is 300 watts. My outdoor boiler blower is 1.4A x 120V = 168 watts and control unit is negligible, so 200 watts total. Then miscellaneous use items plugged in, phones and computers. So I think I will get a 5000-6000 watt inverter that runs on gas. Save some money for something else.
   / Generators, sizes and fuel options? #86
are you sure about the well starting load. i guess it depends on depth. ive seen some deep wells struggle starting on larger generators. my big issue is everything tries starting at same time.
I think it is HP that drives the watts? Mine is only 250’ deep. Even if everything starts simultaneously it is still less than 3500 watts.
   / Generators, sizes and fuel options? #88
Have you found a small inverter that does 240V?
   / Generators, sizes and fuel options? #90
Something like this.
That will probably do.
But for my use I just (about an hour ago) bought the Duromax , I was pleased to see I got my 10% military discount.
Pelican Statue (A53316)
Pelican Statue...
2025 Swict 84in Bucket Skid Steer Attachment (A55787)
2025 Swict 84in...
IRGC40 High-End Mini Golf Cart (A53316)
IRGC40 High-End...
Dayco Val Power Hydraulic Hose Crimper (A50775)
Dayco Val Power...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55301)
UNVERFERTH 330 -...
