Generators, sizes and fuel options?
   / Generators, sizes and fuel options? #71
A generator certainly needs to be integrated with your home tech. Some people can't even flush a toilet if they don't have electricity. Over time, you can integrate your home infrastructure more flexibly.
Yep. This is the key for even more than just the generator. One of the reasons we like the home we are in is it has the master suite on the first floor. So as we age if one of us cannot do the stairs we can remain in the home longer. A wheel chair would be a bit of an issue as there are three steps from the mud room up into the house. However there is plenty of room there to build a ramp if needed.
The prior home owner had mobility issues so there are already extra grab handles placed strategically. We are not taking those out.
   / Generators, sizes and fuel options? #72
Looked at the link and Q & A section, good reviews overall. Just remember you get what you pay for. Every manufacturer builds to a price point to sell to thier audience.
Personally, I would recommend building a small dedicated generator shed for a backup system and exhaust it to the outside with flexible tubing.
Use the airflow that is cooling the engine to blow across the LP tank sitting outside the shed.
Built a couple of these for customers in the past and it worked out for them.
Minimum tank size is important to the equation here. At 9,000 watt surge capacity, you are still in the 250 gallon tank size to run any length of time.
I was hoping with it being an inverter I could do a smaller propane tank. Otherwise going to just use gas. I will borrow a 100# to try when it is cold out to see what will happen. Then if it works go that route. Otherwise gas can and a syphon from my Jeep…
   / Generators, sizes and fuel options? #74
I bought a Duromax 10Kw NON inverter back about 2010. Put it at my son's house in dense suburban Alexandria, Va. Within a few months some construction doofus with a backhoe cut the power lines to his area. They were without power for weeks. Since then it has been run occasionally, mainly to ensure it is ready.
Of note is they offer a parallel kit (XP9000iH-PK parallel kit) with a both 240V 30A and 50A outlet.
linky
/edit for their current XP9000iH Generator.
   / Generators, sizes and fuel options? #75
It is better to set the generator closer to the propane source or to the plug to power the circuit? 30 feet between them
There are a few things to consider.
1. 3 phase electric cable is expensive, big & heavy, and gets stiff in the cold.
2. Propane hose for a generator is much cheaper, lighter, and smaller and won't seem as stiff in the cold. I have QC fittings on mine.
3. Noise diminishes with distance few generators are as quiet as they say they are. You don't want it on top of you
4. Exhaust fumes, are smelly and deadly. The generator needs to be in a well-ventilated area for your safety and to keep from overheating.
I have a 12KW unit with a 30' cord and I wish I could put it further away just due to the noise.
   / Generators, sizes and fuel options? #76
I'd love to just move down south.
I'm on the Texas Gulf Coast and we hit 17'F for a couple of days with it not getting above freezing until 4 days later. Of course the next week it was 72'F , but there were a lot of burst pipes and very cold folks in the previous week.
   / Generators, sizes and fuel options? #77
Yes, I had to Google it. Propane vaporization has to do with tank size and temperature.
it is misleading that they are called dual fuel then. They advertise using a 20 pound propane tank to run for 5 hours. Is that not possible? I guess?
Somewhere in the fine print it probably says 20LB tank will run for 5 hours at 60% load and 70'F. The difference between sales and marketing is that sales don't know they're lying.
   / Generators, sizes and fuel options? #78
Lot's of timely info here. Few questions though.
I'm needing a generator or two also. Based on online calculators I figure 10KW would be the max I need, but often (for months) less than half that.
We run a lot of computer equipment and I've a whole house surge protector. I've fried an expensive dishwasher circuit board before I got the wh surge protector.
so Q1 - Would the surge protector work with a generator?
I was actually thinking of buying EVENTUALLY two ~7KW inverter generators. These would be more movable and several times my power has been on but my MIL's was out, thus I could loan a generator easily.
Q2 - Does anyone here run generators with a tri-fuel kit?
My generator of choice (Honda) only offers gasoline, but I've got LPG and natural gas is coming to my road.
Yes to both questions.
Surge protectors are common with RV users on the shore power cable. You can use the same cable and surge protector on a generator.
There are a (very) few gasoline/LP/NG units out there. I'm not aware of any diesel combo units.
   / Generators, sizes and fuel options? #80
Maybe this will help.
I had a 6.5KW Duromax that threw a rod this past summer. I had run it only on propane and it was probably underpowered to run my RV trailer. I know I couldn't run both AC units with it.
Duromax gives a 3 years non-commercial warranty. Since I had bought it on Amazon it was easy to show when I had bought the unit.
They couldn't replace the unit because it was no longer in production. Instead, they cut me a check reimbursing me for the cost of the generator. It took a while to get the check, weeks even, but I was still stunned and amazed that they followed through.
They were not difficult to work with and I'd buy another one of their units when it comes time to.
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2008 Ford F-250 Reading Service Truck (A55788)
2008 Ford F-250...
2004 Jeep Liberty Limited SUV (A55853)
2004 Jeep Liberty...
