The "thumb"
/ The "thumb" #1
WinterDeere
Super Star Member
Rural 'burbs, north of Philly
John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
@Sawyer Rob had posted this in another thread:
It has a thousand uses, I use it all the time, it's been one of my "best buys".
SR
Serendipitous timing, I was both contemplating a grapple and setting up to modify my own 3-point forks for JDQA loader use. One of my primary loader uses is moving logs, all 15 foot lengths, and I do this using a pair of chain chokers arranged as a sling. It works great, but requires a lot of hopping off the seat, and it's not always the safest operation unhooking the chokers while piling logs.
Looking at @Sawyer Rob's rig, I started playing with the idea of using the top link pin on my 3-point fork frame for mounting of a cylinder to control a thumb. I won't need this top link pin when using the forks on the loader, so it's available. It appears all I need is an extra set of tangs welded to the top tube of the fork frame, to let the thumb pivot:
(click for full size)
The tube floating in air is the cross-member on the loader frame, need to make sure the cylinder can't collide with that. Shown here with an 18" log, but tested with 6" to 24".
No binding or collisions in full range of travel:
Only potential problem I see, other than needing some more work to pick metal sizing and thicknesses, is that the thumb may tend to lift small logs off the forks due to forming a "V" with the back of the frame at small diameters:
I thought I could tune this out with some fiddling of the section lengths on the thumb, but this is the best I've been able to do without either giving up max capacity or causing a potential collision / bending metal between the cylinder and loader cross member or cylinder to thumb spine.
If someone can give me a good guess on square tube size and gauge for that thumb, it might save me some FEA simulation work. The cylinder is only 50mm bore, so around 7850 lb. at my tractor's 2500 psi working pressure. Weight is a concern, as this fork frame already weighs a lot, and I'm often fighting for more loader capacity when moving logs.
/ The "thumb"
Oh, one thing I forgot to ask. Think I need grease-zerk pins in sleeves at the thumb pivots? Got a good source or item recommendation?
I'm not sure how just a plain top link pin would do here, as there won't be a ton of pivoting. But then I think of my bucket curl pins, and the fact that they're greased, and how loose some old loaders still get over time.
/ The "thumb" #3
Yes all rotating/pivoting joints must be grease-able or it’ll wear out in no time.
Your design grometry strikes me as a bit odd. Without setting up a basic dynamics model, my intuitive sense after 20 years as a mechanical engineer is that you are losing a lot of clamping power while simultaneously creating very high stress in the pivot points. Do you have a license for ADAMS?
In my mind the point of a grapple is not to pull material back against the fork uprights- it is to clamp down against the bottom tines, or forks. As in, it’s ok if you can’t fully clamp down tight on one small log and it flops around on your forks, because after all, the load is still contained.
Take a look at this option (probably better to just buy one of these than spend 40 hours doing your own design and fab work)
/ The "thumb"
Thanks, @deezler! Yeah, I don't get to do a lot of mechanical design of implements or dynamic work, just a lot of static models for high power electronics, I'm actually an EE (not ME).
But the add-on thumb grapple is not a good option for lifting long logs, as far as I've seen. I like the forks for this much better, even without a thumb. My thinking was that the addition of the thumb can help hold the log back against the frame/base when I tip the forks forward to retrieve (or even place) one from the top of a pile. Maybe I need to give this more thought, though.
You did misunderstand the complexity involved, as I can whip this job out in closer to 4 hours, not 40! I already have all material in my metal racks, other than the hoses and possibly the greasible pin bushings. I do a decent amount of metal fab, so this simple triangle of square tube and one pair of tangs welded to top of existing frame isn’t a stretch.
No license for ADAMS. I do my modeling in SolidWorks, and simulation in Dassault CST. I believe SolidWorks also has a pretty rudimentary mechanics solver built into it, but since I’m running every day CST for my business, I just go to that for most things.
Did you check @Sawyer Rob's post that I had quoted? That's what I was aiming to roughly mimic, using the fork set I already own. Thinking a single rib on top of that square tube could solve any strength concern, along with reinforcing tabs either side of each tube junction. Possibly teeth on bottom side of tube could replace rib atop, if warranted.
/ The "thumb" #5
I really like SR's set up for moving logs. It will not work for me as I need to be able to pick up load that is 6 ft high once the logs are processed.
Would you show what the arm looks like when the cylinder is retracted? Thanks
/ The "thumb" #6
I would want the grapple curved like mine is, it makes a difference in how you can pick things up.
Picking up a 6' high load is no problem with mine.
And yes, you do want it greaseable, mine is all bushed too.
SR
/ The "thumb" #7
Wow! Solidworks sure has changed since the last time I looked at it. I seem to remember it presenting an almost blank screen for work. 😲
/ The "thumb" #8
I think you are on the path to a good attachment and one worth building. Having a thumb on the backhoe has changed my life... And one for the loader would be nearly as good.
Looking at all the pictures and imagining it in use, I'd rather have a curved thumb. Or better yet, some design with a method of clamping out at the front of the forks as well as back against the SSQA frame.
As it is, it would hold a log nicely and close in allows for the weight of a larger log. But a downside happens when you tilt the forks down and raise the grapple to release the log. Then to dump it, the log has to roll all the way down the forks and jumps off the end unconstrained.
It can really build up some momentum rolling like that.
I'd prefer some way to pick it up out at the end... or at least slow it down when unloading.
But I think it's a project worth doing.
My own first designs are rarely as good as the eventually become. I've learned that there very quickly comes a point in the design process where i just have to build it.
A lot of my initial design geometry is pre-determined by what is available in the scrap iron pile. Buying material is more likely to happen in the re-design.
rScotty
/ The "thumb"
A few of my log piles are at least 6 ft. high, shouldn't be a problem with this rig.
Yep, just like this:
Yeah, the inverted "V" created by the forward lower leg and top beam of that triangle was supposed to mimic your curved arm, but without having to actually cut a curve or bend a tube, as that would really increase project complexity with my tools (no plasma cutter). Maybe I could add a short third tube section mitered onto the end of the long arm at 45°, to create that end hook?
I used SolidWorks 2000 and 2003, in those respective years. Then I was away from it until SW 2022, but I don't remember it changing much, other than newer better part mating options. AutoCAD used to present a blank screen, way back in 1980's - early-1990's. Sure you're not thinking of that?
/ The "thumb"
Doh! Yours came in while I was answering the last. Great post, thanks for the pointers. A few quick answers:
Yes, that's exactly what this is! I chose tubing size, tangs, and cylinder all based on what I had in my inventory. If buying I might have gone with 1-1/2 x 3 inch tubing, rather than 1-1/2" square. But I can always add a 1/4" x 1" or 2" spine atop the arm to add strength in the vertical direction, if needed. If I decide to cut a curve in some 6" x 3/8" flat stock, I could actually put a curved spine (tooth) on the bottom of the thumb.
Two options:
First, I could quickly and easily add another tube section mitered onto the end:
Second option is more work without a plasma cutter, but I could cut a piece of 6 x 3/8" flat stock I have into a curve, and weld it onto the bottom of the arm. This might be prone to side-bending if it's just a single thickness with much extension from the arm:
I thought I'd be able to more slowly release it with the straight arm than the curved, to be honest. Have to think that thru, as one serious shortcoming is the fact that the 3rd function I have available to control this is off a "bang-bang" electric solenoid controlled by thumb switch on my joystick, it's not proportional.
Speaking of which I was planning to add needle valves or restrictor plates to the input ports on the cylinders to be able to adjust thumb speed, unless Deere offers some valve similar to the 3-point float-down valve, to do the same right on the tractor.
The most frequent use will be lifting logs off a pile and setting them on the ground for bucking, in which case I think I can control the descent by how steeply I angle the forks down. The other potential use would be lifting logs out of a trailer, but I'd need shorter forks to get into the trailer more easily, and I'd have to be careful not to catch the far wall of the trailer with the thumb. It's a closed-side trailer with a railing about 2 feet above the floor:
Thanks! Yes, spent my career as a design engineer, and I'm all too familiar with those caught in analysis paralysis. Get it close, then build it. You'll learn more from rev.A than you think, and quickly mod it or spin rev.B to be much better.
/ The "thumb"
BTW, it seems some might not have caught that this is not a fresh build. I'm just modifying a fork set I already have. Here's what I already have minus the pair of tangs I stuck on top for this thumb:
These are 3-point only, so I just picked up a pair of JDQA adapters, which will be welded to a pair of extension gussets, and attached to this frame:
/ The "thumb" #12
SR
I did not explain "six foot high" very well. This is what I have to pick up once the splits are loaded into totes:
/ The "thumb"
Those totes usually have an ID somewhere around 38" x 46", which when filled to 5'6" depth (for 6' total height) with fresh-cut oak (63 lb./cu.ft. at 66% stacking density), will contain about 2780 lb. of wood, and weigh a total of 2900 lb. When dry, that wood weight will drop to about 1900 lb., making the loaded tote weigh about 2030 lb. Either way, I'd probably be moving them with the forks on my 3-point hitch, not the loader, esp. over my hilly property.
But you bring up a good point, in that this thumb will be easily removed by pulling two pins. This was the reason I had asked if they needed to be bushed and greased, as pulling greasy pins is always less fun than dry. Perhaps rather than making the cylinder and arm removable, I should make the arm extendible, such that I can just remove the extension (rather than the whole assembly), when needing to grab something taller.
/ The "thumb" #14
I have estimated the capacity of the modified totes at 1.4 cords. I have never lifted one higher than two feet off the ground. My loader is rated at 2700 lbs and has been handling them. But I have flat ground and go slow and easy. Next year I am moving to 1/3 cord bulk bags but they still stand about 6' high.
An idea I had was to mount something like a rotating jib crane with a thumb at the top of the pallet fork frame. By rotating it 90 degrees, it will not interfere with picking up a tall load. When I need the thumb to pick logs, I am not handling a a lot of weight... 300-800 lbs. I only need to pick up a bag or tote every 20-45 minutes when processing logs. I can manually rotate the jib or use a diverter value on the 3rd function circuit to rotate the jib.
/ The "thumb"
I think you must have an error in your math. If we assume ID = 38 x 46" for the standard 40 x 48 inch totes, and you manage to cut your wood to fit without even 1/4" gaps (like Tetris-perfect), your best case 0.52 cords while keeping the total height at the 6 feet you had mentioned early. In reality, given your wood is probably not of a length that perfectly fills the tote, it's probably a bit under 0.50 cord.
Another indicator these are not 1.4 cords per bin. Check the cord weight of firewood, your 2700 lb. loader would get 1.4 cords of most species off the ground. Figure nearly 5000 lb. per cord for green oak, or 3600 lb. after drying. Your estimated 1.4 cords per bin would be 5000 to 7000 lb. per bin.
In any case, my tractor (JD 3033R) is too light to move that kind of weight on the loader, so not relevant to the design of this particular thumb. If I have to move something anywhere near that heavy, it'll be on the 3-point!
/ The "thumb" #16
Several miters of tubing with side plates or gussets would make a strong, curved beak. Flat bar would also give some bite to prevent side slip. A concern on my hillside.
Thick wall DOM tubing to fit your pins for bearing and hubs. Drilled for grease zerk. Spread the load forces and gives good service life.
Nothing like handling trees to test your equipment’s toughness. Hard to beat a long bottom log grapple to handle, rotate and gently place long logs cleanly.
/ The "thumb" #17
That was probably it. The timeframe is about right. I know it was early Windows.
/ The "thumb"
I had CST busy running another project (something that actually MAKES money), so I decided to play with the Sim tools in SolidWorks, when I had a few free minutes. They're actually much simpler to set up.
On a side note, SolidWorks now has a Makers edition for < $10/month (I think it's $99/year), so you guys may want to check it out for any implement design work you have. Just verify it has the Static simulation tool before buying, as I did this in the Pro version of the product.
Anyway, I was worried that my rather light connections planned between the JDQA adapters and the existing fork frame would be too weak, but it appears that the stresses are all pretty low there. Shown here with 2000 lb. evenly distributed on the forks:
(click for full size image)
You can see the stress peaks are all within the existing (factory build Titan Attachments) fork frame, not on any of the components I'm adding for the JDQA. Yes, it's showing 55 ksi at some of the welds on the fork frame itself (Titan's part), which is beyond the yield strength of most steel tubing, but that's really only because I didn't bother to really model the added thickness created by weld beads. The actual stress within my components is all < 10 ksi.
In terms of deflection, again my added JDQA brackets and mounts are not flexing in any measureable way, at 2000 lb. Tip of forks move 0.7 inches, but I re-scaled to 0.2 inch maximum, to get better resolution back at the frame, where I was trying to detect flex of the JDQA bracket mounts:
So, the JDQA mount part of the design looks good to go. Thumb analysis, next. Maybe after that, if I have time to kill this evening, I might circle back and learn how to model the welds at those high-stress joints.
/ The "thumb" #20
I would want the clamp to be able to open flush with the pallet fork back frame to at least the height of a standard pallet. I had one of these and I quickly grew tired of it damaging pallets and took it off and used my regular grapple instead.
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2016 Chevrolet Silverado 1500 Pickup Truck (A61573)
2016 Chevrolet...
2005 Ford F-150 Ext Cab Pickup Truck (A61573)
2005 Ford F-150...
2022 John Deere 5055E (A60462)
2022 John Deere...
Ford Pickup Truck Bed (A61573)
Ford Pickup Truck...
2003 McCormick XTX 185 XtraSpeed Tractor (A63688)
2003 McCormick XTX...
