Thinking of financing a mx54
   / Thinking of financing a mx54 #21
never had a HST but there are enough operators here that probably confirm if properly operated & maintained, the HST will last as long as the tractor. imho having your wife involved in operating the tractor is alone enough reason to go with it over gear. I'd go with the latest grade of SUDT rather than just USD. good luck
   / Thinking of financing a mx54 #22
Another vote for the HST.
Can't comment beyond what others have said really, other than it is a good tractor.
That trailer on the other hand, I would not be okay with..
For starters you said "double 10k axle". While they DO make heavy duty axles that are single tire and 10k rated.....not for $5500. So I can only assume you meant double 5k axles....IE: a 10k trailer total.
A much more common 14k trailer dont add much money, and gives you plenty of spare capacity. With ballast, loader, and an attachment on the tractor I can have my MX weighing over 8000# pretty easy. Which would make me uncomfortable on a 10k trailer.
Also the length.....you wont have any room to move to adjust the tongue weight with such a short trailer......and if you have the loader on, and a 6' bushhog on the back, thats about 24' in length. Can it be done ....sure. But do you either want 4' of bushhog hanging off the back of the trailer and not be able to stand up ramps? Or leave the loader elevated above the ramps and sticking several feet behind the trailer?
Even though trailer prices are high right now....you can find 24' 14k trailers for ~$6000
I looked into the Branson 5520 against the MX54. Won't save any money because of the extra cost of insurance and higher interest. So it seems that Branson is out of the equation.
I started thinking about the mx60, which seems like it would be worth the extra $2,000. which than led me to the m56. How does the m series differ from the MX series. It seems to be 500 lbs heavier, slightly bigger, 6" longer, with slightly bigger wheels. Also the HST transmission is not available in the m56.
I am a little torn as I am farming 32 acres(20 acres pasture), prob not going to be haying more than 20 acres pasture. I am wanting to get a machine I can hire myself out with doing grading or clearing work(will be working with mini-x) - which seems the mx will be better for and I like the compact of the mx but realize I am sacrificing weight and stability.
Is the MX capable of pulling a older round baler up and down slopes? I am not planning on doing any cropping but I would like to be able to rent and use a grain drill once or twice a year.
   / Thinking of financing a mx54 #24
Sure you don't want hydrostatic trans? Gear becomes a real pain when doing loader work...
So long as it has a hydraulic shuttle, directional changes are a non issue and actually better as there is no dry clutch to eventually replace. I'd opt for the HD bucket if you plan on doing any dirt work. The material bucket has a single bottom sheet and is prone to 'smiling. I have both of them. Just my experience and I'd get the bobcat style 2 lever quick attach as well.
This helped me a lot. Still on the fence on which one would be better overall. Hard to fit it all in one tractor. Mostly I think the MX is going to be best but I will be making sacrifices not having the Case IH 585 anymore. Hopefully it is nothing that will hurt me.
   / Thinking of financing a mx54 #26
My MX52 HST for comparison can pull a 72" gannon full of wet dirt in medium range @ 1500 rpm. And at 2k rpm with the gannon full and the rippers buried in clay in low range. The tires are filled. Traction is not a problem.
   / Thinking of financing a mx54 #27
Always keep in mind that with any HST, there will always be parasitic power loss but with a hydraulic shuttle there is none. Far as pulling a round bailer on hills, I'd be hesitant about that depending on what size the bailer is, ie..4x5 or 4x6. Keep in mind that a full bailer can weight a lot. Myself, I don't run loaded tires ever. I run cast centers on both my M9's. Problem with loaded tires running hay is compaction and crushing the hay plants.
   / Thinking of financing a mx54 #28
Just bought a 10.4K, 20’ trailer for my MX for $5900. No where did I see a 14K trailer for that price. Also, I don’t see how you get 8K pounds for a MX. My MX6000 weighs in at less than 6.5k with loader and ballasted tires. With my heaviest implement, it’s less than 7.5k in weight.
   / Thinking of financing a mx54 #29
1600# rotary cutter, loaded tires, 600# cast wheel weights, plus loader and tractor.
Trailer prices can be a very regional thing.
But see these all the time:
   / Thinking of financing a mx54 #30
   / Thinking of financing a mx54 #31
Not sure why anyone would want cast centers and loaded tires when running hay. The Cast centers add an additional 500 plus pounds to each wheel, depending on rim diameter.
   / Thinking of financing a mx54 #32
   / Thinking of financing a mx54 #33
about 1500 more than I paid 6 years ago
   / Thinking of financing a mx54 #34
That trailer in my area is about $11K. I have loaded tires but no cast weights and my 6’ cutter is more like 1000#.
600# weights and a cutter that is 600# more than yours is why I "can" get to over 8k and why a 10k trailer wouldn't work for me.
And trailer prices seem to be easing in the past few months
   / Thinking of financing a mx54 #35
I bought this little beast of a trailer a while back. It legit has double 10k axels. But I agree it’s definitely not $5500 new for 10k super singles and I also agree that upgrading to a 14k trailer for not a lot of money or empty weight increase is a good decision.
   / Thinking of financing a mx54 #36
Well you made the appropriate choice for your trailer. We all need to consider our weights and our uses before making a choice. The trailer I bought fits my needs: it will safely haul my tractor with implement, but isn’t too large for my many other purposes.
   / Thinking of financing a mx54 #37
You seem to be trying to stay under a certain price point as much as possible. If you want a tractor that will last you your lifetime, check out the Yanmar YM359. I think if you compare the specs and $ to the Kubota you are looking at you will be pleasantly surprised. This is assuming you have a Yanmar dealer within an hour of you, which is not always the case.
   / Thinking of financing a mx54 #38
Actually I have a 24k gooseneck but looking to drop to a 14k
My point wasn't to start a feud.
The point was....people look at a bare 3800# tractor and think 10k is more than enough.
But in reality, loader and other attachments, ballast, etc can add up quicker than one realizes.
The cost of buying too small now is alot.
As 4570 said, a 14k isn't much of a penalty in unladen weight or cost. And gives room to grow in the future, or haul more attachments without fear of being at the max.
   / Thinking of financing a mx54 #39
Very true. But I was looking for a trailer that would be sufficient for occasional tractor hauling, but small enough for other uses such as UTV, lumber, hay, feed, etc…
   / Thinking of financing a mx54 #40
Love my gear drive l3240 with a shuttle. No whine and no loader problems. And the wife can drive it just fine.
Jeff
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
2018 Yamaha VX1050B-TA Waverunner Jet Ski (A59231)
2018 Yamaha...
Tafe 45DI (A60462)
Tafe 45DI (A60462)
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
2016 Ford F-150 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
