Tree climbing gear
   / Tree climbing gear #21
I'd say $2500 ish
Thanks.
And if you knick a rope or belt, or put a shock load on a restraint, etc., it has to be replaced, so there's maintenance costs.
For someone that does this more than a few times per year, it might be worth it, but you also have to factor in the learning curve, proper training, upkeep, etc. Plus you have to be in pretty good physical shape.
A lift rental around here is about $300 for the weekend. We just did it last fall. It's faster and safer, in my opinion.
Anyhow, things to consider. Be safe out there.
   / Tree climbing gear #22
Find an arborist or lineman and get a climbing lesson. I have done some electrical work from spurs. It is not easy to climb a 30 foot pole with a few tools. Man lifts are the way to go unless you can’t get one into the location. Cam
   / Tree climbing gear #24
After getting all the proper gear time has to be spent learning how to use it. That is the important part!
   / Tree climbing gear #25
Go for it!!!! I admire youthful energy!!!! Those naysayers telling you different are just envious that you still have that energy!!!! Go for it!!!!
Keep us informed thru this thread of your progress please!!! :cool:
   / Tree climbing gear #26
Tree Stuff
Is where I get most of my rigging and tree gear
Good year end sale on at moment
   / Tree climbing gear #27
Climbing is a mutt's game. Way too many stories that ended poorly and sometimes permanent. If a lack of cash flow is stopping you from renting a lift then rent scaffolding. Secure to tree every three sections and go all the way up. Limbing small chunks on the way back down and disasembling the scaffolding as you go. Its work, but he who has less cash works harder.
   / Tree climbing gear #28
I've always told people that if you are over 150 pounds, don't climb. All the equipment advice has been given above and that is extremely important to follow. A man lift rental or buying is your safest option and there are 4x4 self leveling options out there that can get into most spots. Hunting equipment for tree stands and recreational climbing (or anything of the sort) is and absolute no no! There are reasons the equipment is different as you can cut through your rope, leg and so on if something goes wrong. You need the proper stuff, period. But what hasn't been mentioned is know the tree you are cutting! Not all trees cut the same, some break fast, some split and clap and that is no fun getting a foot, arm or your body sucked in. Others can be rotted half way through and be unpredictable. Never leave a dead man hanging up there, if you can't or won't bring/drop to the ground what you cut, don't even start. Understand the trees around you so you can avoid hangups in other trees, these when freed up can come at you like a missile and when you get hit, it will damage your body. Get training, practice climbing with 100 pounds hanging from you and never, never do this without a spotter. Make sure this person can call 911 when needed and not panic. This is all assuming you are cutting real trees that are lets say over 40' up to 140'. Even smaller can kill you though.
As back ground, I was taught by my logger FIL. Spent 10 years training with him on about every type of tree in the PNW. I climbed for close to 30 years and it is physically demanding hauling up you fuel, saw and gear while limbing as you go. After an incident on the peninsula where my spotter freaked out, I no longer climb. There may come a time where you need to trust your gear with your life and need to jump/push off to try and avoid getting nailed or sucked in... if you are unwilling to do that, don't climb. There is a reason most tree services use lifts these days. Not everyone is geared for his type of work, I tried to teach one SIL how to do this, after he froze at 30' it was a royal pain in the A to get him down in one piece even though I was tempted to just drop the tree with him in it, in hindsight... I should have :)
   / Tree climbing gear #29
In my climbing prime, I was 220 lbs. I knew guys heavier than that the climb.
I'm 240 now and could still do it easily.
   / Tree climbing gear #30
I've heard just as many if not more bad stories about lifts and bucket trucks.
   / Tree climbing gear #31
I had to go back and reread the original post. He's asking for equipment advice. Nothing indicated him wanting talked out of it. Or alternatives to him doing it.
I applaud his youthful vigor. Hopefully those with climbing experience will continue to suggest things that will guide him toward success.
I'll be very disappointed if we don't see pictures of the work!!! šŸ‘
   / Tree climbing gear #32
I climbed into my 220 pound range, now in the 180 range. If you are 240 and can still do it, good for you but I'm guessing you are a bit younger than I am. :) Have you ever raced 150 pounder in prime condition in your prime up some old growth? If so you'd understand what I mean by that. It's also a young mans game.
   / Tree climbing gear #33
I'm 52. Never did old growth. This is east coast. Hardwoods mostly. Different ball game. I've put a few smaller and younger guys to shame but that was on them for running off at the mouth. I'm sure there are plenty faster. There are a lot of variables involved. Rope skill, experience, geometry, physics. I've had my share of phone calls with someone begging me to bail them out after they bit off more than they could chew.
   / Tree climbing gear #34
If he doesn't have experience, I'm going to try and talk him out of it. If he continues, that's on him.
Seen too many sad days in the tree industry. It's usually pretty gruesome or pretty dead.
   / Tree climbing gear #35
I understand. I'll only ask, did you have experience when you started?
   / Tree climbing gear #36
While I see where you're going with that, and can agree that if someone wants to learn how to do something, by all means, they should, he needs to get with some experienced person to learn, and have some experienced person there while he attempts the various techniques that are going to be involved. It's not something anyone should ever do by themselves without a trained partner and emergency plan.
Working on a whitewater course with various rope techniques and the power of moving water taught me this at an early age. It's been reinforced through my current employer's training programs for fall prevention.
While I'd guess any of us could watch videos and practice in our back yards, it's just not something I'd suggest anyone do without adequate backup. ;)
   / Tree climbing gear #37
:) Pushing 60 now. That was always fun. How I got into it was running my mouth with the FIL. I was put in my place pretty fast, but I learned how to do it properly. A lot of skill goes into climbing damn near any tree no matter the type. For now I'll stick with safer things like learning to Bull ride, breaking bronc's and calf catching. All of which has been a circus side show for family. So far only an injured elbow from a flying calf.
But for the OP, don't cheap out on your equipment!
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
2020 BOBCAT T590 SKID STEER (A60429)
2020 BOBCAT T590...
3 Row Twin Row Renaldo Planter (A53317)
3 Row Twin Row...
2016 Cat TL1055D Telehandler (A56438)
2016 Cat TL1055D...
John Deere 4520 (A60462)
John Deere 4520...
2019 KOMATSU D155AX-8 CRAWLER DOZER (A60429)
2019 KOMATSU...
