HD box blade?
/ HD box blade? #21
Agree with the 72" box for a 50 hp tractor. Hydraulic rippers are ever so much more useable than manual rippers. When it comes to earthwork you will need to engage the rippers more occassionally than constantly. Hence the benefit if the hydraulic control. I have stalled the 52hp MX with the rippers engaged in medium range. A wider box would be oversized in my opinion
/ HD box blade? #22
You should also consider a land plane. I wound up buying a land plane instead of the box scraper because it just suited my needs better. It will smooth out rough ground and bring gravel up out of your driveway. Mine is a 7 foot Woods and is well made
/ HD box blade? #23
I have a 7 ft landplane. It's a one trick pony. But it's a trick it does very well. The landplane does not carry dirt so it lacks the ability to truely cut the highs and fill the lows - maybe my expectations were too high. I use it for weedabatement on flat rock free ground.
I did see on here where one guy had made a box end for it (y)
A box with hydraulic top, tilt, and rippers is a different animal. If you don't have the 3 function rear hydraulics then you may as well drag a ground scraper around.
/ HD box blade? #24
It's very rare for find a 50hp tractor with 3 rear remotes. Without owner modification I'd say it's rare to find one with 2 rear remotes.
My Ford has 2. My LP rear blade is hyd angle and hyd tilt. I use a hyd top link. I put an electrical splitter on the blade so one tractor remote runs both blade systems with the flip of a switch on the tractor.
My Kubota has 3. So I can run the top link, side link and hyd rippers of the box blade. Also allows me to run hyd lift of my batwing cutter plus a separate system for each wing.
Not familiar with the OP's tractor so can't comment on how many rear remotes he has or the ease of adding more. Just don't rule out splitters to gain function on a tractor with limited rear remotes.
/ HD box blade? #25
We had shoulders cut into our pond so that it was not an abrupt drop off and the dirt was piled up on the banks leaving a pretty size able mess but the land plane was able to smooth and contour it very well. Mine has scarifiers so it works well on about everything thing I’ve used it on. It also - as stated earlier does a great job making the driveway look new
/ HD box blade? #26
ALL depends on what one is cutting into. I rarely use my rippers. What matters the most is WEIGHT. My 7' Tuffline weighs 1,200 lbs and I used it extensively when I was laying out my fencing lines. Other than the crappy hydraulics (not locking- drift really fast; caused me to break some linkage; I tend to run around with something like a board pinning the bar up) it's met all my needs. I'd have held out for a used one if I didn't have that fencing project bearing down on me: new box-balde and a dump trailer were purchased; I sold the dump trailer but still have the box-blade).
/ HD box blade? #27
I have a Woods 6ft on my 33hp and it does a really good job for road grading. Bought used from a rental yard for about half the new price. It looked like brand new and maybe rented out just a couple times.
/ HD box blade? #28
For weight, I added a 7 foot section of train track and welded it on the top of the box. Good addition for digging in.
/ HD box blade? #29
Hi All,
Looking to buy a heavy duty box blade this coming spring. Seems like there are a lot of options out there.
Looking for a true HD model for a 52 HP compact tractor. Rear tires are 66" so im looking at 72" wide on the box blade. Trying to get the best cost on a really well built unit that I can.
So far it seems that the two best on paper are either the Woods BSM or the heavier duty model from Everything Attachments.
The EA model looks nice and well designed, and is obviously we'll reviewed, but I am thinking that it has benefited from a lot of online popularity and marketing. The woods is heavier overall, and I believe is made of a heavier gauge steel.
Just looking for any guidance between these two, or any suggestions for other brands.
Don't care about brand, just want good quality for as good a price as I can get.
Everything Attachments builds many attachments including box blades in Newton, North Carolina.
/ HD box blade? #30
Hi All,
This is mine. A roll-over box blade. As such it's built like a tank. Since its a specialty item they are not cheap. I use mine to maintain trails where I can't turn around and this allows me to pull, push or drop the scarifiers.
/ HD box blade? #31
Hi All,
I have a 7 ft box blade on a 47hp [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] and it works well without using the ripper teeth not sure if it would pull with the teeth down. I also just bought from Styron ag online and it was a good experience so far that being said it was a drum mower that I haven't even uncrated yet but I think the prices were good
/ HD box blade? #32
I have used Gannon boxes for 40 years in my business, they are pretty good. I had several Case 570lxt and older and newer. For my home use I restored this old Gannon mounted on Ford 445a.
I like wheel weights plus liquid filled tires ( beet juice these days). Once you put the box down the back is pretty light weight.
You can always make your own valve arrangement. The offset lever is the ripper. I am also going to make linkage for the side tilt so the lever swings left and right. Just to different.
/ HD box blade? #33
Look into Armstrong Ag, out of Brenham, TX. They have a few lines, from basic Cat 1, to some very stout Cat 2, and 3 models. I have a 72" Cat 1 with six manual rippers and this thing is more than capable with my LS 4140 XR.
/ HD box blade? #34
You sure keep it looking nice!!!
/ HD box blade? #35
I use a pull behind box blade I picked up for a few hundred dollars. The trailing wheels ride on the smooth surface cut by the box blade. The end result is unbelievable. I thinks it’s a 7 foot model. I pull it with a Kioti CK2610. I would not trade it for a three point box blade. The outcome between the two are night and day.
/ HD box blade? #36
Each have their place. To get the full benefit of yours install a tilt cylinder. 🙂
/ HD box blade?
Thanks to everyone for your info.
I had some life stuff come up that pushes this back.
I also was given a nice little three point blade by a cousin that made this a little less urgent. I still want and probably need a box blade though.
I looked into roll over BBs after seeing it here and think that's what I'd like but those babies are expensive! And it seems like no one really makes them anymore. I don't understand why unless it's that the costs are just too high for most of the market.
I'll be looking for something in the next few months I hope though.
And, I don't think I mentioned my use.
I have a mile and a half of mountainous forest road to improve and maintain.
I'll hire out a dozer to widen the road and do much of the initial improvement & heavy earth moving work but want a box blade to do the finish work and long term maintainence.
The road has some steep grades where water creates some pretty good ruts that I will need to be able to fill in and grade.
Most of the road will be left as dirt, but I'll also need to be able to manage some sections that I will gravel.
/ HD box blade? #38
For that much road this is the ticket. Probably can get a decent price on this one. My road is only a mile and I just bought a Champion 720a series 3. Keep in mind that grading requires proper moisture and compaction.
/ HD box blade? #40
I'm not I'd be able to pull that with my tractor. :)
You don’t have to it’s self propelled. My time is valuable to me, with one of those it’s much faster and cleans ditches better. When you have to re-establish the crown it is so fast. I still have my Gannon scraper box tractor for certain things where the grader doesn’t fit.
2014 Wacker Neuson ST45 Compact Track Loader Skid Steer (A61567)
2014 Wacker Neuson...
DECKED TRUCK BED SLIDING TOOLBOX (A62131)
DECKED TRUCK BED...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
(2) BUNDLE OF MISC SIZE USED TIN UP TO 31' LONG (A62131)
(2) BUNDLE OF MISC...
UNUSED KJ 33'X25' DBL GARAGE STEEL BARN SHED (A62131)
UNUSED KJ 33'X25'...
40ft High Cube Shipping Container (A61166)
40ft High Cube...
