Help identify this loader valve
/ Help identify this loader valve #1
suburban99
Could be danfoss (vickers) 30542-6C...
It's on a 650 FEL on a 186D looking for the spec sheet or information on relief valve.
Doesn't have a conventional relief valve.
/ Help identify this loader valve #3
/ Help identify this loader valve #5
information plainly states set relief valve pressure 2000psi. Relief valve is on top right of first picture. Pressure can be adjusted with shims. Yes, your 3 point also has a relief valve.
/ Help identify this loader valve #6
Not so sure as it looks like a plug, rather than a relief valve, but can't hurt to unscrew the plug and find out.
/ Help identify this loader valve #8
It has always been my understanding that all loader control valves have relief valves. Maybe I'm wrong but do know the Eaton sight is showing a relief valve on the one that has been attached. I can't imagine using a loader without a relief valve. I cause my loader valve to relieve quite a bit when using my loader. Without one I am pretty confident my pump would be trash.
/ Help identify this loader valve #9
I agree, but looking at the literature and the picture of the valve, it appeared to be a plug. It could be a shim relief under there. Being it is an older Yanmar, anything is possible. They could be depending on the tractor system relief, but you are probably right.
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2025 Fendt 943MT Vario Tractor (A63111)
2025 Fendt 943MT...
(2) Bell 500 Gal Saddle Tanks (A64119)
(2) Bell 500 Gal...
Caterpillar 941/951B/955 Maintenance and Service Manuals (A63117)
Caterpillar...
Beverage Truck Body (A61573)
Beverage Truck...
2005 MACK GRANITE CV713 T/A DUMP TRUCK (A64276)
2005 MACK GRANITE...
