If you have Toolcat questions, ask them here...
/ If you have Toolcat questions, ask them here... #701
Use a slide hammer type seal puller like this one. Drill a small hole in the seal and screw in a metal screw. Use the SH attachment that hooks under the screw head (second from right) and carefully pull the seal.
Slide Hammer and Puller Set, 14 Piece
/ If you have Toolcat questions, ask them here... #702
Thank you ruffdog, i'll let you know how it turns out.
/ If you have Toolcat questions, ask them here... #703
in the past I have used a self drill screw to thread into the seal, usually 2 opposite or 3 evenly spaced and used a pry bar to ease it out, seems on older machines the seals were way better, these new ones are tin and wear faster
/ If you have Toolcat questions, ask them here... #704
How do I clear the service reminder on my 2021 Toolcat (with a keyless start).
I cannot find instructions how to do it in the service manual.
Are these instructions correct for my machine?
/ If you have Toolcat questions, ask them here... #705
My service manual for my 2017 G series 5610 (section 60-190 Maintenance clock) agrees with the post above with minor changes:
Key OFF (press OFF for keyless), Press the HOURS button to turn the panel ON, Press and hold both HOURS and AUX HYDRAULICS till panel displays reset.
/ If you have Toolcat questions, ask them here... #706
Thanks. I’ll try to use your page reference to find it my manual as well.
/ If you have Toolcat questions, ask them here... #707
Have a 2007 with 2 codes:
50-73
50-75
Anyone have a code list?
/ If you have Toolcat questions, ask them here... #708
Just replaced the controller on a 5600 Toolcat and now the glow plug and aux hydraulics lights are flashing, the temp gauge is pinned to max...
It starts ok, but won't go into gear or anything else. Lift tilt and traction functions disabled even with arm rest down.
What's going on? Is there a reset procedure for a new controller?
Any help appreciated!!
/ If you have Toolcat questions, ask them here... #709
What was the reason for the new controller? Does it have keyless start? Did you double check the connections for loose,broken,bent pins?
/ If you have Toolcat questions, ask them here... #710
50-73
50-75
50-73 = Throttle Sensor Ch A Out Of Range High
50-75 = Throttle Sensor Ch B Out Of Range High
/ If you have Toolcat questions, ask them here... #711
The Enter Code button stopped working on the old controller. Yes, keyless start
Yes, double checked connections as well
/ If you have Toolcat questions, ask them here... #712
33-23 = Controller not programmed
Well now, that makes a **** ton of sense...
Think maybe the dealer I ordered it from would've mentioned that was needed, huh
FFS
/ If you have Toolcat questions, ask them here... #713
FFS
Let us know what happens! (y)
/ If you have Toolcat questions, ask them here... #714
FFS
Also, it makes sense that the controller needs to be programmed to the serial number (master code) so you then can program operator codes (keyless start).
/ If you have Toolcat questions, ask them here... #716
I have an 2012 rtv1100 and a 2020 svl75(cab).
what expectations should i have by getting rid of these 2 and getting a new tool cat. The svl75 is mainly used to grade my mx track. It’s just another front loader for the farm. The tv is mainly used by my wife in spring for garden and by me after storms for fence repair. Neither get used a lot. The toolcat looks interesting. I would go with the dump bed over the 3 point, all though a grader box would be good for the track. Wife likes the dump. How good can the tool cat dig dirt with a tooth bucket? I also have a heavy kubota root grapple, would toolcat be able to handle that?
/ If you have Toolcat questions, ask them here... #717
I expect that you would really like it and it would do what you need it to do.
Put a SSQA plate on the back of the grader box:
Very good. This is a 6 foot wide 1 cubic yard bucket:
Yes, this 6 foot wide Monster Grapple weighs 1,168 pounds:
The loader will lift over 3,000 pounds.
Have you seen this thread? Toolcat 5610 F and 5610 G Series Pictures
Good luck and keep us posted.
/ If you have Toolcat questions, ask them here... #718
I also had a RTV 900 that I traded in on the toolcat. The comparing the two, the TC is a SUPER heavy duty version of the RTV that also has a construction grade loader arm to do work. It is a niche piece of equipment that can do a lot of different tasks in comfort. Drive one and watch videos....if it fits what you expect from it, it will be an asset.
/ If you have Toolcat questions, ask them here... #719
I have a 3 point lift attachment for the rear which fits into the receiver hitch, great to drag a scraper or whatever behind which doesn't require PTO
/ If you have Toolcat questions, ask them here... #720
I'm having the same issue but in the rear on a 2005 Series What was the final results
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
John Deere 3025E (A53317)
John Deere 3025E...
2008 INTERNATIONAL MA025 FLATBED (A55745)
2012 CATERPILLAR 308D CR EXCAVATOR (A59823)
2012 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 FORD F450 XL SUPER DUTY TRUCK (A59823)
2012 FORD F450 XL...
