Please Help
/ Please Help #1
JD User
JD 4400
hi I was wondering if anyone can help me with rear hydraulic auxiliary hook up to use 2 hydraulic cylinders on my snowblower attachment . I don't know where to tie in or hook up...I have a 1999 John Deere 4400...
/ Please Help #2
/ Please Help
See if the nearest JD dealer will print you off a hydraulic schematic of your tractor.
This may help give you a general idea of what you want to accomplish
It doesn't matter if you put one or ten rear remotes in the line, it's just plumbing
I'm not familiar with that tractor so I can't be much more help.
Okay great thank you...I did get a schematic for a auxiliary kit install but not very helpful, and kit is not available anymore...
/ Please Help #4
Welcome to this forum
According to Tractordata.com JD 4400 has open center hyd system. So you will need to locate the power beyond port on your tractor. I suggest to contact some tractor salvage yards to determine if they have the used scv kit you need. One tractor salvage yard is shown below.
/ Please Help #5
What is your level of hydraulic understanding and general mechanic ability?
Are you able to buy and aftermarket valve, find a location to mount it yourself, and have hoses sized and made? cause if they no longer make an auxiliary kit for that old of a machine it may be your only option. But you have to have a solid understanding of hydraulics in general to even attempt
/ Please Help
Hi and good morning, I don't have a solid understanding of hydraulics but I am very mechanically knowledgeable and have the know how on how to get the work done. I can buy a 3 spool control valve, get hoses made, fabricate a bracket and mount it somewhere I just don't understand or know where to tie into the hydraulic system on my tractor...
/ Please Help #8
JD
Do you have a FEL ( Front End Loader) on this tractor? Reason for asking is that with FEL it might change where you can tie into your system.
/ Please Help
JD
Hi, yes I do..
/ Please Help #10
Where is the FEL valve mounted on your tractor? I am not familiar with Deere but I believe some models have the FEL valve remote mounted and others bolted go the transaxle housing. This again will make a difference in how they are plumbed into the curcuit.
/ Please Help
JD
I currently have a front end loader but want to add a snowblower attachment to the rear but have 3 separate hydraulic controls 1 for the chute discharge up and down, 2nd for chute control left to right and 3rd top link cylinder ..
/ Please Help
Its mounted to the right under seat...
/ Please Help #13
"Most" valves have three basic flow ports (not "work" ports or A/B ports) , one is PB or "power beyond" (suppliest hydraulic fluid to next valve in line), A P or "power" port which is input to valve body from preceding "power beyond", and a T or "tank" port when excess hydraulic fluids are return to reservoir (tank) or HST
Once you understand the sequencing of valves you can probably add you new valve anywhere in the sequence of PB/P lines between valves...
Suggest you study some about hydraulics system a bit to get a handle on concepts once you understand concepts the rest is just mechanical connections...
/ Please Help #14
If mounted directly under the seat are their any external lines besides the four going to the loader or is it direct mounted to the trans axle? If external lines how many are there? If direct mounted would have to see if deere offers power beyond cover option for your existing valve.
Any chance you can post some pictures of the existing valve showing mounting and plumbing. A picture might be worth a 1000 words…
/ Please Help #15
In an open center system the valves are plumbed serially. Flow goes from one valve to the next via each valve's PB port.
The flow usually goes from the pump to the loader valve to the rear remotes if you have them to the 3pt hitch. The 3pt cylinders are usually inside the transmission case at the back. The loader valve (or factory rear remotes for my tractor) may bolt right on the transmission case and feed the 3pt through that interface. If your loader valve feeds the 3pt through the case then you'll need a model specific adapter to get access to PB.
If the loader valve has three ports in addition to the four work ports leading to the cylinders, you're set- one is PB. It would likely go to the very back of the transmission case. You can insert your valves into the chain there.
If there's only two, then one may be PB. The other will be the feed from the pump.
LIGHT TOWER (A56857)
Truck Tractor (A61568)
2006 Freightliner Auger Truck (A61307)
2006 Freightliner...
2015 Chevrolet Express 2500 Passenger Van (A61568)
2015 Chevrolet...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
