Hydraulic augers?
/ Hydraulic augers? #21
Digga 1DSS ordered. I got the 12 inch tungsten bit and made sure they spec'd the adjustable mount.
Contemplating this one myself, curious as to what your total cost was and looking forward to a review once you put it to work!
/ Hydraulic augers?
Give Jim at Ferrara Equipment a call. Great guy and easy to work with. Digga is shipping mine directly to me so it'd be no issue getting one to Texas.
Jim Southward
Ferrara Equipment Company
(804) 937-8137
jsouthward@ferraraequipment.com
/ Hydraulic augers? #23
I expect you will be very pleased with FEL hydraulic driven auger performance. The performance of FEL vs 3 point hitch is like night and day. Did you get the hex or round driven shaft?
Please update thread with your experiences as some other contributors are interested in how the motor and auger bit perform.
/ Hydraulic augers?
It's a 2" hex connection.
Unfortunately they're 4-6 weeks lead time at the moment so that's a bummer but it'll be here before long.
/ Hydraulic augers? #25
I've only got a 3ph auger, but could've definitely used down pressure as I've had to limit my augering to the months here when when the ground has a bit of moisture in it because our clay becomes nigh impenetrable. When I had to have a hole in mid-August, I literally pre-dug 6" by hand with a pick, filled it with water, and refilled it the next day when the previous water had soaked in (and dried, more probably, in the 10% humidity); then hand-dug down another 6" so that the next soak could be more effective, and only then was the auger without down pressure able to do anything.
I've considered getting a SSQA hydraulic auger at auction as the local-ish place had a bunch a couple months ago. I figure that my augering almost never uses much more than my tractor at idle, so if the gpm of my tractor was a hair low (9.8 vs 10) it should still be fine. The main reason I didn't pull the trigger is that I'm hoping that my augering at this property is mostly done at this point with a perimeter fence being complete. The occasional future hole for trees or whatever will be done in late fall when my 3ph unit is effective.
/ Hydraulic augers? #26
Found my LP SA20 auger at a Kubota dealer that also sells construction equipment. Has the medium flow motor, it's slow (way faster than hand digging), never had to drill new hole because of striking tree root. FEL has enough weight to use float for down pressure. When tractor starts to rock sideways, pop it out of float, auger needs time to chew thru tree root. Applying down pressure only raises front axle and tractor will twist right or left. You'll have to pull auger and realign tractor to finish hole.
Reconnecting auger - If you connect hoses together to keep couplers clean, the motor can free-wheel and you have a 2 axis swivel connecting motor to frame. I built a parking stand to address these issues.
Another toy for the home owner (not the right tool for commercial contractor) is a stump plane.
/ Hydraulic augers? #27
How much torque does it seem to be putting on the loader when chewing through roots & stumps?
I'm guessing nothing like when you scrape with the bucket more on one side than the other
/ Hydraulic augers?
I got my 1DSS last week. Has anyone with a hydraulic auger figured out a good storage solution when not on the tractor?
/ Hydraulic augers? #29
i'm kinda jealous, though most of my hole-drilling should be complete on this piece of land
next place, i'll buy myself this sort of unit no doubt! i've been most unimpressed by the 3ph auger. never got it stuck, just more of a problem of it not biting into the hard clay half the year...
/ Hydraulic augers? #30
I dont have an auger for my loader but I do have one on a 19hp micro EX. Even with my hard clay/shale and a 12in bit it never really hit anything that you couldn't work it though. It's very hard to stop the auger and you can actual aim the auger. Mine dosnt spin fast enough to throw the dirt out so in a 12x48in hole you may have to remove the auger 3-4x including a clean out pass. Way quicker than a single stuck 3pt auger.
/ Hydraulic augers? #32
I built a dolly with pressure treated lumber and heavy duty casters from HF.
Nice dolly. Any chance you could post a picture from a little further away? Specifically, showing how the ssqa plate is situated.
I bought an ssqa hydraulic auger last year, and had hoped that it would store easier than my previous 3 point octopus.
At the moment I am doing the brute force, totally disassembled approach.
/ Hydraulic augers? #33
the only reason i didnt get one for my tractor, which also has a rear hydraulic powerpack unit, is because i hardly use it anymore after i installed my fencing. Heck, if i need 1 hole dug to repair a fence i usually hand dig because hooking up auger takes so long. Now if i was constantly using one, id definitely go front mount.
/ Hydraulic augers? #34
Here you go. It is incredibly simple, the key is to secure the the gearbox to the saddle with a ratchet strap. I added an additional cross piece for augers to fit on it as shown in the first picture. It is so easy to mount that it isn’t even a consideration for drilling a single hole, unlike the old 3 point one.
/ Hydraulic augers? #35
Thanks for the additional pictures and info.
I'll give the dolly andratchet strap a try!
/ Hydraulic augers? #36
I wonder if you bolt some metal to block the forward movement of the power head like... (plz excuse lousy art)
you may be able to drop it down in one go without the strap?
/ Hydraulic augers? #37
I just bought this one on a farm auction a couple of weeks ago. No idea what brand. I have to get a global to SS adapter. I'm in OKC for work and can't wait to get back and get it all hooked up. $1200. They had 3 of them on the sale. Almost bought them all.
/ Hydraulic augers? #38
holy co
w. what a great price.cant go wrong with that
/ Hydraulic augers? #39
My solution
/ Hydraulic augers? #40
holy co
Yea, It'll take another $500 or so to get the adapter but I'm looking forward to punching some holes with it. Also getting a Limb Hog so hopefully I can 2 purpose the SSQA adapter.
UNUSED MOWER KING-AGT SAII100 (A64281)
UNUSED MOWER...
2025 78in Bucket Skid Steer Attachment (A61572)
2025 78in Bucket...
UNUSED WOLVERINE QUICK COUPLER 2 (A64281)
UNUSED WOLVERINE...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
Bulk Lot - (10) 8in x 20ft Fat Lip Pump Hoses (A63689)
Bulk Lot - (10)...
