Good morning!!!!
   / Good morning!!!! #159,091
Morning all, 34 and cloudy, getting to mid 40s
Worked late so no garage work done, just ordered more parts. Amazing how expensive building materials are, even after prices came down a bit, a small bit it seems.
Wngsprd - the wild dangerous hikes through wegmans. be careful out there :cool:
Drew - I took in a few of the last tomatoes, left them on the counter and they eventually ripened.
back to work, then need to start getting outlet boxes off the first garage wall and make sure I have enough space to order/receive the 30 foam boards.
Stay safe and be well,
These vultures are huge, big enough to scare the dog when they take off. All seem to have left, for now.
   / Good morning!!!! #159,092
Good Morning.
33 and going to 40 today, clear to partly cloudy skies and no rain or snow.
Didn’t do too much yesterday after getting home, finished up equipment maintenance with the exception of the tractor, might get to that today. Wife is going off to a 3 day “fiber festival” to display and sell her alpaca goods. I’ll be loading up the trailer for her after I hook it up and give it a good pre trip inspection. Other than that, nothing planned.
   / Good morning!!!! #159,093
Good morning! 45˚F, the wind will start to come from the South again warm up to 59˚ this afternoon, that's when I'll mow the yard but before that the Kia gets a new battery.
The outdoor batteries took a beating this Summer. The Kia's start/stop function has stopped working like the Ranger's when the battery cannot keep a high enough charge. No trouble starting but a good pre-indicator to get the battery changed soon. Batteries in the Texas heat are lasting about 3.5 years, their warranty of course is 3 years.
   / Good morning!!!! #159,094
Good Morning!!!! 48F @ 5:15AM.
Some clouds this morning will give way to generally sunny skies for the afternoon. High 64F. Winds light and variable.
TBN seemed to be down for a bit for me this morning. Anyone else?
Shortened battery, and starter, life is a predictable consequence of that insane start/stop scheme to save gas, Don. How much do you have to save to replace a $200 battery or $300 starter?
Found and fixed a bad network cable yesterday, which seems to have helped with a flakey connection to a remote switch. A new Network Video Recorder finally finished setting up the drives, took more than 24 hours. Streaming images is now much faster and smoother, and there's oh so much more room to keep them. And it'll handle a lot more cameras.
Started a spline lube on the new red motorcycle yesterday, and found the transmission to be in good shape after it was pulled from the bike. Sure was dirty on the outside, though. A trip to the parts washer eventually got it cleaned up. With the back of the engine exposed, I'll renew the main engine seal and oil pump o-ring today, then start putting it all back together.
The transmission I purchased a couple weeks ago showed up yesterday, somewhat loose in the box. FedEx had managed to break it free from the wooden brace the seller had made, but otherwise the transmission seems to be intact. I'll know more later when I have a chance to take a closer look at at.
Town run this morning, then back out into the garage after it has a chance to warm up a bit.
Hang in there, gang, Friday's comin'!
   / Good morning!!!! #159,096
The insurance claim guys are supposed to be here this AM for more roof work. That's the claim that got legally messing with the insurance company and various contractors since March. And the big job has not even started yet. LOL.
Good luck with the insurance scammers.
   / Good morning!!!! #159,097
Insurance they gamble you do not lose you bet you will
   / Good morning!!!! #159,098
You can save 3-5% if you drive in a lot of stop start traffic, a quick google search shows. But in the Texas heat it always start's back up before the light changes to green, so not even that much, plus I disable it, form its default on, each trip when I remember. However according to Wiki idling uses 3.9 billion gallons of gasoline a year and the start stop feature eliminates the idle time.
The Prius was the first vehicle I had that used this feature.
I think the only use is to warn you of a low battery so you can replace the battery before you get stranded.
   / Good morning!!!! #159,099
Good morning! 28 now, may get to 35 today.
We got our first snow last night. Maybe 1/2”, the drive, sidewalks, and road are clear. The house is toasty…..the wood burner is doing its job.
Not sure what I will get into today. Likely what ever I decide to do will somehow morph into something totally unrelated. Yesterday was one of those days. Started out with plans to do some more work on the trailer interior, ended us spending hours making a Lycette sprung pillion seat look right and fit a bike correctly. It was truly a PIA.
Everyone stay safe out there!
   / Good morning!!!! #159,100
40º going to 70º. This is what we pay for to live here. ;)
Spent part of the last 2 days diggin up a yard drain. Tractor and Bobcat did 90º of the heavy digging. Seems the eucalyptus tree roots squished the plastic pipe flat... probably with the help of the expansive clay soil.
I'll finish excavation of the pipe today and cut out the damaged section and test the upstream flow. If all goes well I plan to relay the pipe replacing a sharp 45º bend with a 36" electrical sweep... we will see how that goes. If successful it should make snaking the drain much easier. This drain is subject to a debris from Eucalyptus trees and pea rock from the dog pen where it originates. Have a great day !
2013 Volkwagen Tiguan SUV (A56859)
2013 Volkwagen...
2021 UTILITY VS2DX 53FT DRY VAN (A59575)
2021 UTILITY VS2DX...
2020 DRAGON ESP...
7x16 Enclosed Spray Foam Trailer (A57453)
7x16 Enclosed...
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
20ft Jumper Cables (A57454)
20ft Jumper Cables...
