log grapple design/dynamics? 3 pt
/ log grapple design/dynamics? 3 pt #21
The one pictured has a single double acting hydraulic cylinder to push the jaws open and pull them closed. If you have power to the rear, or a kit is available for your tractor to install it, it would be quite easy to get power to it.
/ log grapple design/dynamics? 3 pt #23
With 100 feet to move, time and fuel are likely not a large issue.
"A small parcel" was mentioned by the OP.
Ok. Let's do the math and the op can judge for himself:
A rear grapple might grab two of these stem pieces, He will have to maneuver backward to position the logs to line up the rear grapple especially for a multiple log "bite" so a lot of back and forth movements. A turn will be 200' and I will discount the back and forth for positioning because he would do that anyway to load a trailer but his loading work will always be in front of him.
So he carries say only 6 logs on a trailer but that is 400' saved or more than the length of a foot ball field. If he carries 8 logs, that is two football fields saved. It adds up surprisingly fast.
How long in time is a turn?
How many logs does he have?
How large in diameter are the stem pieces?
Does the op even care about time?
Whether it'd be a small wood plot or 90 acre logging parcel, forwarding logs has it's place.
As far as logistics, he already has a front grapple. All he needs is a small trailer and he doesn't have to fabricate anything. Heck, he can even load a ground chain, wrap up the chain and skid those out.
I'll leave it up to him because no one here knows the variables.
The op might just love to tinker and make things so creating a rear grapple simply adds joy to his life.
I, being a retired logger, looks at things in time only because time was money.
My boss even frowned upon (and that's putting it mildly) his guys "blipping" a chainsaw because that wasted fuel.
Efficiency was king so right or wrong, that is the approach I bring forth.
Well said Arrow.
Time is not that important, I am doing it for my own and the landowners use not selling any firewood.
I do enjoy spending time building things in the shop, I build and sell the grapples for the front of tractors, skid steers and I have even built one for a mine excavator. I am thinking if this works well I could market it as well. More of a R&D really.
I did have a thought this afternoon, for maneuvering's sake I could use this on the front so I am thinking about making it convertible or at least the boom, take it off the top of the 3 pt set up and move it to a quick attach plate on the front.
I can't really just drive up to a lot of the pieces and use the front grapple, too many stumps, deep ruts from the big skidder etc.
If it was my land I would have had it logged a bit different, I would have had the logger drag the entire tree to the landing, cut the logs off and leave the top where it is, repeat. It's only a 5 acre lot and I feel they made more of a mess than was necessary although I do understand they are pressing to maximize profits.
So far no one has really addressed my initial concern of the actual geometry of the working grapple part. It doesn't matter now as I have it welded up today, a single double acting cylinder above the pivot point so it will close up on push and pull to open. I happen to have a 2.5" bore x 6" stroke cylinder here. I used the PAD method (plywood aided design) LOL I'll get a pic or two tomorrow as I am whipped.
I do understand that I won't have 270* of rotation and will pretty much have to back up to them straight on, I'm ok with that, I have cut a stump or two here and there so I can get around.
If I had help I would just park the tractor with winch at the landing area, run the cable out to the short pieces and drag them in and repeat. It's too much work alone and I have bad knees.
I am going to add some sliders and hooks to the cable so I can haul 3 or 4 pieces at a time.
I'll keep ya all posted!
Thanks,
DAve
ETA: I can't see getting a trailer around in there although I would love to build a small forwarding trailer with a grapple on it.
/ log grapple design/dynamics? 3 pt #25
Well said Arrow.
Thanks,
DAve
Well Dave, those are the "variables" I mentioned.
I agree w your premise of leaving whole stems as opposed to what they did. That is so weird to me that they did that unless someone told them to cut up the stems but why was there no landing established? That was one of the first things we did..
My crew would never log a parcel the way you describe plus we had a company who wanted the slash so clean up was almost immediate.
You sound as a very skilled metal worker so my hat's off to you in that regard and you're right, your geometry question remains up in the air unless it's hidden in one of the example build plans some contributed.
Too many people here (including me) telling you what to do instead of answering the question.
Yep, first thing I did. I think I have it figured out. Of course it would probably have been a good idea for me to see one in person prior to attempting this..lol
Anyway, I just braved the cold and went out to the shop and snapped a couple of pics of what I have so far.
Notice the pivot holes are not on the same plane, this seems to be needed so the will bypass each other instead of smashing ends.
The whole thing is about 24" tall
Instead of using chains I think I am going to use to 3/4" D rings like one of the pics I saw.
/ log grapple design/dynamics? 3 pt #28
That looks like a good start. (y)
/ log grapple design/dynamics? 3 pt #29
I'm going to build a 3 point log grapple, I have never really seen one up close so I don't know how the geometry is for opening and closing. Anyone build one or have a schematic of one? I have searched but have come up empty handed. Just the open/close part I need help with. Thanks
It will be this design:
We run a grapple for decades. We put a winch on the grapple. No longer use the grapple part, it is the winch carrier now. Winch was so good, we bought a FARMI, and it's really good. Winch is a lot better. My brother and I used to have short wood pulpwood trucks with cable loaders. I can't stress enough how much better the winch situation is. I been at it since Jimmy Carter was president.
/ log grapple design/dynamics? 3 pt #30
If I would want to haul full length trees for a good distance this is what I would want ... a logging winch is good if you can't access the tree to haul it out to the trail but not skidding it for 3000ft
I totally disagree with that, what do you do with that grapple arm when you can't get the tree through a muddy spot, or up a hill?? With a winch, no problem at all!
I'd MUCH rather have the winch on that small tractor...
SR
/ log grapple design/dynamics? 3 pt #31
I look forward to seeing the progress. Not sure why some are trying to convince you not to build something you are interested in doing. Keep the pictures coming.
/ log grapple design/dynamics? 3 pt #32
Smart Grapple out of Montana used to make 3pt and ssqa grapples. Bypass tongs would completely close. Could easily pull up small trees. Optional hydraulic winches.
Very well made and very expensive.
Bought a ssqa model going out of business sale. modified to 3pt hitch also. 3pt works best with hydraulic top link. Local tree service company made me an offer I couldn’t refuse. They love it for moving big wood on tight customer’s property with minimal ground damage. Loading logs long ways into the back of their chip trucks. They feed big limbs into their big chippers with it. Hugh manpower saver. They got the county contract to clear high hazard trees along the roads.
I see them every once in while. Still using it almost daily for 15 years. Had to rebuild winch (Warn) once.
/ log grapple design/dynamics? 3 pt #33
SR
Good point, the winch definitely as its perks, the combination of both would be optimal. ... I simply see the practicality/productivity of simply being able to back up to a log close the clamp and leave, then being able to open the clamp to drop the log without getting off the tractor.
/ log grapple design/dynamics? 3 pt #35
SR
This is why I much preferred the cable skidders over the grapple ones to drive.
They were the only type my boss would get. Logging buddies were a mixed bag of opinion at the time but the advantage of the grapples was that you could eliminate the ground guy who choked up stems.
Getting off a tractor to do so, is much easier than climbing in and out of a skidder hence the separate choke setter.
As with everything, big grapple skidders have their place but my heart leans toward the cable type which kind of has become a dinosaur.
Actually, so has the ground logger here in the north east relinquishing to all kinds of machinery.
/ log grapple design/dynamics? 3 pt #36
To answer a question, I am wanting it to grab a bunch of 6'-10' logs that the logger left scattered all over my friends property. I used my winch to skid the longer stuff out but it's a pain to use it on all the short stuff. I'm not even sure why they cut it into such pieces, maybe to get it off the usable log underneath or something. I have a grapple on the front so I have hydraulics on board, I too thing the tractor is too light to have this on the front although I'm not opposed to the idea but I have limited lifting capacity and having the log out there another 2'-3' isn't going to help. I don't have to drag them far, 50'-100' tops to the landing area. It's a small piece of property.
You asked about construction and not about practicalities. I would think that the 6-10 diameter of your logs would determine the curvature of the grapple arms. Maybe size for 12 in diameter on the inside and opening out at least 16 in. You might think about making the claws somewhere in the 18 inch long range. I would think it would be prudent to make the business edges serrated for better grip. I would also offset one claw slightly versus the other so the two can scissor to some degree and not come together exactly. This can be done by making one claw wider than the other and will allow you to hold smaller logs. You will also need to take into account what kind of cylinder here -with the sizes and duties that you are looking at here and maybe using 1/4" plate, I would guess off the cuff that you be using something like a 1.5"-2 inch cylinder. Go too big and you're going to mangle your fabrication.
I would suggest you make a mock up of the mechanism out of something like particle board or MDF or even stiff cardboard, glue it together, and make sure it articulates like you want it to, doesn't interfere, and covers the range of sizes you are interested in. Then you can trace the pieces on the plate for the plasma cutter. I recall somebody saying he likes using "CAD" -"cardboard aided design" for these sorts of things and I think it's appropriate here.
Good luck with your project and make sure you post pics
/ log grapple design/dynamics? 3 pt #37
The majority of loggers around here are highly mechanized. With the feller buncher making tidy piles of sorted (by market) wood, in the woods ready for the grapple skidded to haul off to the landing.... grapple sliders make perfect sense.
A friend who hand cuts runs a winch skidder that also has a grapple. But he bought it used but does take advantage of both methods.
/ log grapple design/dynamics? 3 pt #38
Keep in mind, the OP is talking about a 25hp tractor not a couple hundred hp skidder.
There's no doubt in my mind, that a skidding winch would be a MUCH better performer on a little tractor over a 3 point grapple, that is IF he wants to actually get something done. On top of that, the winch is so much more useful for many other things
I don't think this is about what actually works better...
SR
SR
I have a winch as well but it's a pain to use alone for these short logs. I plan on adding a couple of sliders on the cable of the winch so I can drag at least three of them at once.
Said winch:
/ log grapple design/dynamics? 3 pt #40
This grapple just has two 1" arms and they bypass to close to zero. One cylinder in top makes it happen. No rotator. I don't see the need for one. We put a hydraulic winch on it, now the tractor stays out of so much junk.
2014 Ford Focus Hatchback (A61569)
2014 Ford Focus...
2004 Ford F-250 4x4 Pickup Truck (A61568)
2004 Ford F-250...
2016 Boxer 700HDX Compact Skid Steer (A63116)
2016 Boxer 700HDX...
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
(2) BUNDLE OF MISC SIZE USED TIN UP TO 25' LONG (A62131)
(2) BUNDLE OF MISC...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
