Titan skeleton rock bucket mod
/ Titan skeleton rock bucket mod
Well I skirted this attachment yesterday. I raked rocks 1" to 4" into a row and then scooped em up with the solid bucket. Sure I got a little dirt but it was definitely 80-90% rocks and I just poured them over the edge of the creek gorge. Done. F those rock buckets :ROFLMAO:
/ Titan skeleton rock bucket mod #23
That is certainly a cheap and easy way to go. I have piles like that all over the property where I raked the rock and all the weed/sod from a first plow. Now I have mounds of decaying weed, rock, and dirt. I may have to use your approach and just find a bunch of low spots :)
/ Titan skeleton rock bucket mod #24
Don't blame you. The reason I know about rock buckets is that after a flood here, the EPA and their contract excavators re-routed our creek. One day they simply pulled out, leaving us to deal with a pile of dirt and rock almost as big as our house. After looking at the pile for a year, I began sorting out the rocks & dirt. Big job, but the dirt is worth saving.
We are still in the process of dealing with the rocks. Some get built into rock embankments, some reinforce the creek bank. And some are still in piles.
rScotty
The rock walls in the northeast are a testament to backbreaking farm work from an era gone by.
/ Titan skeleton rock bucket mod #26
^ amen to that. What's amazing to me is when you go hiking through the woods in PA and NY and come across an impeccably stacked stone wall. Some family of farmers toiled away to move and stack those stones like a work of art... and now we haven't even farmed that field or pasture for decades.
I lived in PA and CT. The woods are indeed crisscrossed in walls of stones that have stood for hundreds of years. And no JD tractor moved those stones. It was man and horse or ox power.
I was able to reclaim a couple of really rocky areas with the landscape rake and the modified rock bucket. I think the toothed bucket will work best in loose soil and for hard soil with loose rock on top a smooth edge bucket would be best. Cheers
/ Titan skeleton rock bucket mod #29
I think you are right. That's how I ended up with two rock buckets.
I'd love to see some before and after pictures of the work you did.
On our Woods Landscape rake it turns out that there are a couple of oddities with the design that I suspect have kept it from ever being a more popular implement. The Woods is the best one I know of, but it may be possible that it can be improved.
1. The trailing wheels are very close to the rake tines. If there is a reason for that I can't figure what it would be. It's easy to make the trailing arms any length, and there might be an advantage in making the length adjustable. So why were they made as one length and that so close? As the rake hops around the wheels get pushed sideways enough to interfere with the tines.
My thought is that the wheels should normally be rolling on raked ground a foot behind the tines or blade - whichever one is in use.
I've ordered a couple of pieces of 3"x3" x 1/4" x18" angle iron to extend the wheels farther back.
2. I have no idea how in the world that the manufacturer expected one person to raise and lower the grader blade accessory attachment. Or to latch it in place. The grader blade is a clever extra feature, but way too heavy for one guy. As is, I raise it by lowering the whole rake onto a stump and latching it in place with a chain. Will have to come up with something better.
3. I think the angling pivot needs work. It's awfully sloppy - but the parts book doesn't show the expected quarter inch wall bushing I thought might be missing.... so maybe it is supposed to be sloppy. I'll hold off on that until #1 and 2 are done.
rScotty
I wish I knew the answers. There is a real interesting relationship between the distance of the wheels from the times and how it effects or limits the angle of the tines in the ground.
I was trying not to dig with the tines so I wanted the bar low and the tines as non aggressive as possible. This required a wheel that extended down below the tines when the tine bar (where the tines mount) was flat or neutral.
I had to remodel my welding area. And I'm just about ready to get back into the rake gauge wheel project. I have some 12" caster wheels but they do look as durable as yours. I think I will have about 4 inches clear between the wheels and the tines.
/ Titan skeleton rock bucket mod #31
I wish I knew the answers. There is a real interesting relationship between the distance of the wheels from the tines and how it effects or limits the angle of the tines in the ground.
I had to remodel my welding area. And I'm just about ready to get back into the rake gauge wheel project. I have some 12" caster wheels but they don't look as durable as yours. I think I will have about 4 inches clear between the wheels and the tines.
Oh...good thinking. I hadn't gotten that far into it myself - but now that you mention it is obvious that the angle of the rake to the ground is going to make quite a difference.
I'd best start by assuming that the main body of the rake is horizontal.
Woods has a wonderful simple and quick way to adjust the wheel height. It is just a set of six or seven half inch spacers that slide under the vertical pivot of the wheel.
You can see it on on Messick's Parts documents.
/ Titan skeleton rock bucket mod #32
If you were trying to improve how much material you are scooping each time here... You were on the right track .
Instead of welding the cutting edge between the teeth, weld across the top of all the teeth. Like shown in the blue highlight . A common straight plow edge like goes on a box blade would work fine
Common mod done to excavator buckets with teeth
View attachment 770056View attachment 770058
By golly I think yo Sir are right. Maybe should have used this approach
2013 KENWORTH T800 DAYCAB BOBTAIL VAC TRUCK (A65643)
2013 KENWORTH T800...
2001 Sterling Single Axle Dump Truck SELLING OFFSITE (A62613)
2001 Sterling...
(2) New 14-17.5 NHS tires on John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 14-17.5...
2021 CATERPILLAR 320 EXCAVATOR (A65053)
2021 CATERPILLAR...
NORTHWESTERN ENGINE HOIST (A64277)
NORTHWESTERN...
2019 HINO 268 4X2 S/A NON CDL BOX TRUCK (A59914)
2019 HINO 268 4X2...
