Anyone have a small hydro electric system?
   / Anyone have a small hydro electric system? #21
I have researched micro hydro for at least 10 years now. This fall we decided with the current political climate that it was time to pull the trigger.
My stream produces 500 gpm+ at it’s peak and down to a slight trickle in the summer. I designed it to take advantage for the Dec-may peak. It should produce roughly 3kw continuous. With this power I can power and heat my whole house.
I have 2 turbines custom built to my stream specs by Langston Alternative Power. as stated earlier I get 500 gpm of flow and 60ft of head in a 1,000 ft run of 8” pipe. Up at the house is a 12k Growatt hybrid inverter and six LifePo 4 batteries capable of storing 30kwh.
I also have 20 Solar panels that will be installed as soon as I get the hydro completed. Right now I’m racing the winter weather.
I also read in a few posts above about the maintenance involved. Well, if you design I the system right there really isn’t any maintenance to speak of. The key is keeping debris out of the penstock and turbine. That can be done with a Coanda screen.
You can buy the whole coanda box but they are super pricy. So, I ordered just the screen and built my own box for it out of concrete and saved about 5k ! I added a pic of my weir and coanda box and the hardest part of the whole project, burying the 8” pipe Cree side in the giant rock garden.
Anyhoo, here are a few pics of my progress
   / Anyone have a small hydro electric system? #22
That is a great deal of power.
3000 X 24 hours equals 72 kilowatt hours per day.
Solar panels: 20 X 350 watts equals 7000 watts, about 8500 kwh a year or 23 per day.
That is almost 100kwh/day.
My experience:
20 375-watt solar panels=7500-watt output to a 7600-watt inverter. Output is about 9100 per
year or about 25kwh per day. (Grid-tied, no battery).
The output powers a 2600 Sq. foot house with all electric kitchens (2) electric laundries (2)
and Mini split AC. We get a little heat from the Mini split, but our boiler is natural gas.
We also power a plug-in-hybrid car (about 12,000 miles per year).
We have produced as much power as we use since we turned the solar on 3 years ago.
This is not in sunny California, it is in central Minnesota.
When I find lights left on, I turn them off and say to The One Who Must Be Obeyed:
"Do you think we get free electricity around here?" (From when we had kids in the house)
She says "Yes, yes I do."
Your milage may vary.
Best of luck
regards,
R
   / Anyone have a small hydro electric system? #23
My experience:
   / Anyone have a small hydro electric system? #24
Roric,
keep in mind this is my max output Which will easily come in the winter when my stream is raging. We plan on running our whole house and heat pump which I actually just got today. ( mrcool 4/5 ton universal system ) my inverter is a dual phase 12k. 7k on each leg max. My solar panels are 230v which I hope will come close to powering the house in the summer. Keeping in mind that we live in the mountains and don’t have A/C and don’t plan to run the new AC/ heat pump in the summer.
   / Anyone have a small hydro electric system? #25
So whatever happened to those water wheels that used to be in the path of a stream, that generated energy for so many different uses?
David from jax
   / Anyone have a small hydro electric system? #26
I'm following this thread with great interest since I would dearly love to install hydro, wind and or solar power generation on my property. Due to my situation however, the initial cost and return on investment are a big problem for me.
No mater which method I choose, I won't be able to generate enough power to completely serve my needs so I will have to rely on the grid to make up the difference. I would have to use my home generated power as a supplement which means adding more wiring & equipment to interface the two sources.
Generating the power is one thing, storing it is another. Batteries are expensive and increase maintenance costs. Using the grid as a storage medium is another option but where I live, solar is the only source accepted by the local power company. The energy generated is used to offset usage and appears as a credit on my electric bill.
A lot has been said here about generating power but little about it's storage and practical use. How do those with operating systems deal with these issues?
Thanks in advance for any suggestions you may have.
   / Anyone have a small hydro electric system? #27
Offsetting the grid with hydro, solar or wind is one thing, being able to store that power for when you "want it" is another. I think hydro is a more 24 hour a day source than solar or wind, but apparently it's use becomes a seasonal source rather than a day/night source. Rather than trying to store it, a lot of people use backup power for when they need power and their wind/solar/hydro aren't supplying power if they can't pull it from the grid.
My Sister in CA has enough solar capacity to run her whole house plus some, but if the grid goes down at night, their 22KW generator fires up and runs. Batteries would require an additional investment and maintenance issues that would affect their "retired lifestyle".
We all have to choose what we have available and what works for us, within our means.
David from jax
   / Anyone have a small hydro electric system? #28
It's been nearly fifty years since we bought this property on a mountain river...At the time I looked into it and was told that at least 11 feet of fall would be required to harness enough energy to make it worthwhile...and then there was the issue of dealing with high water during storm floods etc..
   / Anyone have a small hydro electric system? #29
you might be surprised the amount of power your creek can generate. Have you done any measurements? If so what are they? As far as storing the power, in my system I have six LifePo4 lithium phosphate batteries. You’re right that they are very expensive, they were the single biggest expense in my entire system. However, there is no maintenance at all with these batteries.
i Don’t understand what you mean when you say you would have to use your generator also ( unless you plan on going totally offgrid)
my inverter will “blend” power from the grid if for some reason I’m not making enough power with my system.
if you wanna discuss further you can PM ,me and i will give you a call. I am by no means a professional and I also have a lot to learn about it but I’ll answer what I can and I can turn you on to the guy I bought all my equipment from. He is a pro and has been working with this stuff for years
   / Anyone have a small hydro electric system? #30
You may want to look into it again. you can make power with very little head if you have decent flow. That low head turbines have come a long way recently
2015 FREIGHTLINER CASCADIA DAYCAB (A50854)
2015 FREIGHTLINER...
2016 MACK CXU613 DAY CAB (A51222)
2016 MACK CXU613...
1991 Gmc Top Kick Dump Truck (A50514)
1991 Gmc Top Kick...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2019 CATERPILLAR 236D3 WHEELED SKID STEER (A51242)
2019 CATERPILLAR...
2008 Kenworth T300 T/A Knuckleboom Crane Truck (A50323)
2008 Kenworth T300...
