BX2750 snowblower compatability
/ BX2750 snowblower compatability #1
homey53
Rutland, VT
Kubota RTV 900, 2016 Kubota BX25 DBL
I have a 2016 BX 25D and I've been looking for a used BX2750, front mount, 50" snowblower. One showed up on Craigslist today, that was used on, and purchased with, a BX2200 tractor back in 2003. The owner says she's had some back problems, and can no longer do the yearly installation and removal, and is looking to sell the blower. In her ad, she shows both a manual for the blower, and a manual for the quick connect sub frame hardware. On both front covers of the manuals, it says the blower model is BX2750, and the subframe and hardware model is BX2751. It says they are both for the BX tractor series. Can anyone tell me if those units from a 2003 BX2200 would be compatable with a 2016 BX25D?
Thanks,
Tom
/ BX2750 snowblower compatability #2
I cannot tell you for sure. I own a 2003 BX2200 but no snowblower on it. I would bet that the front mount blower will fit your BX25D if you have 100% of her mounting hardware, the subframe and all that. I'd be mainly concerned that your BX25D chassis (being set up for a backhoe) could have a lot of steel in the way of the snowblower subframe installation... at least that would be the likely conflict area I think. I'd do some extensive comparison if I were you. There have been several threads about the BX2750, front mount, 50" snowblower and you could probably do a "thread search" and get some help there.
Don't know what your situation is but if the lady has back problems ... ? Maybe she'd just part with the whole tractor and blower and save a lot of grief ?
I don't doubt for a minute that she has all the necessary hardware, and could put her hands on it instantly. You kinda get a feeling about people when you listen to them. She knew her tractor inside and out, and has been installing this thing for winters, for years, and removing it at season's end. She says she's just not physically able to do it ant longer, because of her back.
Something I didn't say in my original post, was that I called my local Kubota dealer and asked what he thought? He said that the part # BX2751 for the "Male quick hitch, and Sub frame, had changed, but that the part was still identical, and only the number had changed. And same with BX2752, which is the "Mid PTO KIT". The number was no longer BX2752, but the part was identical, and the old numbers were referenced in the descriptions on both the new part numbers. Then he threw in the, "But don't quote me on it". LOL I think I'm safe in going ahead and buying it, but I was just wondering if anyone else may have had a similar experience? As far as buying the whole package, she didn't offer, and I didn't ask. I'd need a divorce lawyer if I did that.:)
  • Good Post
Reactions: JWR
/ BX2750 snowblower compatability #4
The subframe hangs off the front and doesn't extend rearwards very much if at all, so that probably wouldn't be an issue. My subframe, originally on my bX1860, wouldn't work with my new BX 2370 due to the longer wheelbase. However, my dealer ordered and installed the parts necessary to make it fit--basically a longer splined input shaft and drive shaft (I negotiated this mod when purchasing the 2370). I know this doesn't really answer your question, but my suggestion would be to enlist the help of your local dealer.
/ BX2750 snowblower compatability #5
This link to an old post may help (hope it works)
The mid pto kit is the issue.
I have the 2750 blower on my bx24, works well. I also have the 2763 plow which sees the most use for the small and wet sloppy snows we get here SE NH.
/ BX2750 snowblower compatability #6
I have a BX2230 which is the next newer version of her BX2200. When I was looking for anreplacement snowblower, I found one off a BX2360 I think. Not sure on it, though. But the quick hitch has a longer shaft going towards the input drive shaft. (Like George mentions longer wheelbase.) You can get a shorter shaft from the dealer if you need it. Maybe looking at Tractordata.com and comparing the wheel base numbers. Jon
Thanks George
Thank you, Jon
Thank you for your reply. Looks like worst case scenario is a different shaft.
/ BX2750 snowblower compatability #10
I just looked at tractordata.com and it is not the difference of the wheelbase, but the length of the tractors are different. Jon
Thanks,
Tom
So I ended up buying this BX2750 snow blower that a gal had used on her BX2200 tractor, which I believe she said was a 2003? After getting my hands on it, I find that the output shaft from the BX2751 sub frame quick hitch is short, by about 3 inches. And that is exactly why NHBX steered me towards an old post from a guy that experienced the same problem. There is a shaft that is 14+ inches long that looks like I can replace the original with, that is only 11+ inches long. The part number of the new shaft is 70060-02728, and costs $190.49. Now, do I buy that, or cut the mid PTO shaft, and weld in a 3 inch piece of schedule 80 iron pipe to extend, and save myself about $150. 00, to make up that 3 inch difference? What say you?
/ BX2750 snowblower compatability #12
Nice score homey53,
I’m no expert and haven’t stayed at a Holiday Inn for many years lol but a couple of thoughts anyway.
The mid pto is 2500 rpm
Mods to shaft need:
u-joint alignment (orientation)
straightness
balance
strength
Although $190 ain’t cheap for the correct input shaft, neither is having a drive shaft come apart and damage the tractor. Only you can make the decision what’s best for your situation. Good luck 👍
/ BX2750 snowblower compatability #13
Between the BX2230 and the B25D, the wheel bases are the same but the lengths are different per tractordata.com. Hence the difference in the lengths of the stub shafts on the front mounts. Bearing arrangements are a bit different between them also, I have both. The long stub shaft unit will be converted when I need the spare snowblower. Jon
Nice score homey53,
Mods to shaft need:
straightness
balance
strength
My son expressed the same concerns you did, pretty much word for word.
So Jon, I'm not sure I'm understanding what you're saying? If the bearing arrangements are a bit different as well as shaft length, it isn't just a matter of swapping out the different shafts?
/ BX2750 snowblower compatability #16
homey53, maybe these will help
Attachments​
/ BX2750 snowblower compatability #17
I don't know if the difference in the bearing arrangement has to due to the longer shaft or maybe Kubota found a better way to deal with the mounting of the bearings. Cheaper method?
Attachments​
Thanks NHBX. Yes I brought those drawings up on the Messick's site.
So with the blower I have (BX2750, and the Male Quick Hitch and SubFrame, BX2751) If I change out the existing Output Shaft (Part # 70001-00772) to the longer Output Shaft ( part #70060-02728), I should be OK?
Thanks,
Tom
/ BX2750 snowblower compatability #20
hey53, did you get the snow blower shaft worked out? When I was at the dealer,he suggested bringing both units and quick hitches and shfafts into them to compare and get the correct shaft ordered nstalled for me. But one is on the tractor for the winter and I can't be down waiting for it. I have not looked a the parts sheets to see if the dimensions are listed for each shaft. Hope you get it figured out. Jon
Roller For A Ripper Roller w/Toolbar (A64127)
Roller For A...
2004 International 4300 Box Truck, VIN # 1HTMMAAMX4H667102 (A65563)
2004 International...
Rolling Shop Table (A64127)
Rolling Shop Table...
New Holland L180 (A64126)
New Holland L180...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
2018 FREIGHTLINER CASCADIA  125 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 FREIGHTLINER...
