Binding trailer jack - half butt fix
/ Binding trailer jack - half butt fix #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
My top crank trailer jack had been working fine, not too difficult to turn. Then fall came.
Now my enclosed 10K trailer has been sitting outside since I bought it in ~2019. I had been filling it this last year for an 800 mile trip, from Va. to Ms.
It was getting so I got serious exercise cranking it down to raise the tongue so I could get the tongue weight for a final "balance".
The jack is one of those with an enclosed top.
Looking online I need to remove it from the trailer, disassemble it, brush and grease the screw (all thread rod).
Being that I've only limited tools at my Virginia house I decided to take the EZ way out.
I dropped the "foot" off, sprayed up the tube with garage door lubricant.
Now I know I probably still need to go in and brush the thread and lay down a layer of grease, but it was a quick fix and seemed to work.
/ Binding trailer jack - half butt fix #2
Buy a simple zerk fitting kit from Harbor Freight. Tap a hole near the top of the cylinder. Install the zerk fitting. Now you can grease it up anytime you need to. :)
In a quick fix, you can spray PB Blaster with the stick wand into the near circle gap of the crank and the tube cover. PB Blaster is basically propylene glycol.
The problem with the zerk approach is that there' just a relatively slim all thread rod in a a tube about 1.5 inch diameter, and the bottom of the tube does not have a cap. I could probably waste about 4 tubes of grease trying to thread the rod.
I've got no gap at the top, I had tried spraying PB B'laster in the top, it just puddles up and SLOWLY leaks in with virtually no improvement in cranking.
/ Binding trailer jack - half butt fix #4
Bruce
Yup Bruce, that's what I figure I NEED to do, but spraying lube was a lot quicker.
/ Binding trailer jack - half butt fix #8
You could crank it up, lower the tongue onto some blocks or on to your hitch, then remove the jack to grease it all without needing a second jack or specialty tools
Instead I just put it on my scale setup, took the foot off and sprayed it.
/ Binding trailer jack - half butt fix #10
you also could simply drill a tiny hole in the top and spray lube the jack screw from the top.
/ Binding trailer jack - half butt fix #11
Just about every jack I have owned has nearly frozed up on me. Typicaly il take them appart, wire brush the rust off the threaded rod and grease them. I hold the leg of the jack in the vise and chuck up the rod into a cordless drill and run it back and forth a few times. They work great for years after that.
I have 2 jacks from the mid 90s and one that's about 10yrs old.
2022 FORD F-750 SUPER DUTY DUMP TRUCK (A63276)
2022 FORD F-750...
2001 Freightliner FL112 T/A Wet Kit Day Cab Truck Tractor (A64556)
2001 Freightliner...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
2013 Keystone Springdale Camper (A62613)
2013 Keystone...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
Volvo Water Truck, 3306 Cat Engine (A62679)
Volvo Water Truck...
