Leaks are Driving me ....
/ Leaks are Driving me .... #1
Oldtoad
Kennebec County, Maine
Kubota L4310, Bolens-Isiki
Old faithful woodsplitter is a workhorse, processed many cords of wood.
'90's MTD tiltable I-beam, 8hp B&S original motor, everything hydraulic has been replaced.
But it leaks, fix one thing, another squirter erupts, drips go postal.
Thinking of going to a hydraulic shop. Nothing close by, means a hike...
Ideas?
/ Leaks are Driving me .... #3
Depends on the connection type. If they're NPT threads, thread sealant. If they're JIC, just snugging them should work, absolutely no sealant. If they're ORB fittings, no sealant, and just tighten them. If still leaking, replace the O-Ring. I never use teflon tape on hydraulics. Something like Oatey's Great White or similar.
If it's leaking someplace else, obviously you've got another issue, but usually it's just a fitting someplace that vibrated loose.
/ Leaks are Driving me .... #5
Also, I don't know your machine specifically, but I've got rubber shock mounts on my splitter. They were a combination of rock hard, or missing after 40 years. I replaced all of them, and the vibrations away from the engine mounting plate calmed down nicely. Could be a cause for connections getting loose on you.
/ Leaks are Driving me .... #6
I'm also curious what's leaking specifically. Makes a big difference in trouble shooting/repairing. If stuff is randomly blowing (like a hose) I'd look at your valves since it's an older unit and maybe service that and make sure your over pressure bypass is functioning.
Where is it leaking from? Hose fittings? Cylinder or pump seals?
All fittings have leaked since the hydraulic rebuild.
New cylinder, pump and control.
Have been going over them, taping and tightening.
Had the mechanic over, he taped and tightened, stopped the leaks, but a squirter came back the next day of usage.
Thinking maybe replace all the fittings and lines if need be. Weak link perhaps.
Loctite?
At first dismissed this, on second thought, a little dab might do it.
/ Leaks are Driving me .... #9
Try a real thread sealant. You'll be surprised. I hate working with it as it's messy, but it works so much better than tape, it is well worth that slight headache. If it happens to be Loctite brand, fine, but you don't need/want a threadlocker.
Had to look up the fittings and the Oatey's, thanks.
Old stuff likely vibrates loose.
Going out and give the rig a look over before I ship it off.
Ordered the Oaty's from Lowes, will do a locker pickup rather than walk around looking for it.
Worth a try.
Thanks again.
/ Leaks are Driving me .... #12
Good luck. I hate chasing leaks.
/ Leaks are Driving me .... #13
You dont use pipe tape on hydraulics. You need pipe dope and stuff that works on oils.
/ Leaks are Driving me .... #14
Hydraulics dont take tape. They take o rings if anything. I would guess a combination of wrong fittings and improperly made hoses
/ Leaks are Driving me .... #15
NPT hydraulic fittings do need help. I did not have good results with teflon pipe dope. The kind I used was a lubricant not a hardening sealant. What works for me is LocTite 545. It's made specifically for NPT type hydraulic fittings where the threads are also the seal. Regular thread locker LocTite (#242 usually) might or might not work. 545 works every time. I have used enough different LocTite products to trust them when they recommend one vs another for a particular application.
NPT fittings seal by deforming the threads. If yours have been assembled and taken apart too many times they may not seal as well.
Thinking of doing some fittings replacement.
Going to check out the LocTite 545, compare it with Oaty's.
Winter is coming, so much to do. 🙂
/ Leaks are Driving me .... #17
Some pictures of some of the trouble areas would do wonders.
Cause right now we are just "assuming" they are NPT threads based on your "mechanic" taping the fittings.....
However.....I know ALOT of "mechanics" that dont have a clue about hydraulics. If you are taping JIC fittings that could be big problem is shards of tape ended up on the sealing surface.
/ Leaks are Driving me .... #18
Yep most hydraulic fittings don't get tape of sealant. Just the ones where the threads are the seal. The only one of those I have seen here in the US are NPT. My splitter has a lot of NPT fittings and no JIC ones. NPT is a little cheaper and since most things like valves, bungs and filter housings are NPT, using NPT for the hoses means fewer adaptors to leak and raise the BOM cost.
With the LocTite 545, clean any tape or sealant off the threads. I try to get the oil off too but I don't go crazy with solvents, though that won't hurt. I let it cure for a day before using it.
I think that the problem is the control is unsupported.
/ Leaks are Driving me .... #20
Unsupported valve is pretty common on a lot of log splitters and not a problem.
The bigger problem is your use of black iron pipe fittings that are rated for probably 1/20th of the pressure you splitter produces
APPROX (50)UNUSED CORRUGATED METAL SHEETS (A64281)
APPROX (50)UNUSED...
2005 Peterbilt 378 Day Cab w/ Wetline 834826 (A62613)
2005 Peterbilt 378...
2011 Polaris RZR 900  (A62679)
2011 Polaris RZR...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
275 GALLON POLY TANK W/ CAGE (A64280)
275 GALLON POLY...
UNUSED WOLVERINE RSB78-78" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
