sliderbuck
Has anyone found a replacement cylinder that will work for the curl on the loader? $450 a piece from Mahindra. Anyone know the specs on the stock cylinders?
Check out Magister Hydraulics cylinders on Amazon. I am very happy with my reasonably priced larger bore (slower action speed/more power) "replacement" curl cylinders for my 1526. I have been carefully enjoying success with stressful back blading, Ratchet Raking, etc, the last 2+ years -- Verboten, per most scut FEL manufacturers! As the cylinders are made in Ukraine, there may be supply problems due to the war...good luck.Has anyone found a replacement cylinder that will work for the curl on the loader? $450 a piece from Mahindra. Anyone know the specs on the stock cylinders?
Happen to have a part number for them?
Not for your 26XL...check out Amazon for a good manufacturer video on measuring for the Double Acting Hydraulic Cylinder you need.Happen to have a part number for them?
Seems like i read somewhere that the 1526 cylinders will work on the max26 though. Which ones did you buy from amazon? Curious what the specs is on them.Not for your 26XL...check out Amazon for a good manufacturer video on measuring for the Double Acting Hydraulic Cylinder you need.
Still never answered as to why they were needing replaced?Well finally got it back up and working. Used the cylinders below. Had to open up the holes some for the pins. Holes was for .75” pins. Mine are .885 diameter. Other than that went right in. Had to find fittings to go from the cylinders to the hoses. Local place had them. Cheaper alternative to stock replacements which cant be found anywhere right now.
Pardon Our Interruption...
www.ebay.com
Does it really matter as to why i replaced them?Still never answered as to why they were needing replaced?
Yea, you probably would have gotten alot more help and alot better suggestions if people know exactly what you are trying to accomplish.Does it really matter as to why i replaced them?
His explanation wasn't strong enough??Yea, you probably would have gotten alot more help and alot better suggestions if people know exactly what you are trying to accomplish.
But whatever. Keep it top secret.
What explanation?His explanation wasn't strong enough??
Guess he did have a "weak" explanation.What explanation?![]()
Probably too embarrassed to say he bent them back dragging![]()
Same here. Do it correctly and nothing will bend.You mean your not suppose too, darn I’ve been doing it for years.
