Culvert Install
   / Culvert Install #1
HawkinsHollow
SE TN
Branson 3015R
When I bought my property 5 years ago it became very obvious if I wanted to reach the other side of my pond I was going to need to make a bridge or culvert over the ditch that feeds the pond. For 8 months out of the year (12 in wet years) navigating the swamp to cross this small ditch is difficult at best. I have been across it twice, both in rented machines and both times were almost a disaster. The ditch is not deep, but deep enough and often times full of water. It was time to do it right!
I had originally thought about making a bridge out of free I-beams I got from a friend, but then got my hands on a cheap 18" reinforced concrete pipe ($100). It seemed to me that dropping a pipe in a hole and coving it with dirt would be easier. The culvert location is 1/3 of a mile from the barn down a steep hill and along a trail. Bobby Branson handled the pipe shuttle no problemo. I am estimating this pipe to be in the 1800 lb range (I could be wrong though).
My dirt pile was also up near the barn. So I had to shuttle the dirt from this location down to the culvert 1 bucket at a time. Took about 8 trips. The culvert is not completely finished yet. Plan on putting a concrete apron on the front of it which will allow me to backfill right to the edge of the front, and keep the dirt from washing out around the pipe. But honestly water coming through here is not moving with tons of energy so I am not worried about it getting washed out.
Sorry, having issues upload pictures of the final product, but I am sure you can imagine what it looks like. Excited to gain easy access to that side of the pond. Not much over there yet (due to limited access). I have plans on renting a mini ex and cleaning up that side and cutting a road into the hillside, eventually putting in another access up the draw to the top of the ridge.
Feels good to FINALLY get this project done.
   / Culvert Install #2
Looks great, would love to see the finished pictures. A headwall is an important addition. You can pour it in concrete by placing a sheet of plywood flat against the pipe end and pouring behind it. Insert a piece or 2 of rebar to keep it in place when it cracks.
   / Culvert Install #4
New neighbor wants me to help put a 3ft steel culvert in her creek for livestock use. The water can come pretty swiftly down this creek when the upstream dam releases any water which hasn't happened in years but could if the current drought condition reversed. I'd rather see her use a concrete pipe. I have a 3ft conc pipe under my main entrance drive in the same creek. My main worry is the steel is going to rust - but I guess all I can do is mention that which I did .... and not sure how much weight it will bear.
   / Culvert Install #5
If her culvert drains and doesn't have standing water it will last a very long time before it rusts away. Under corrosive conditions 20 years. Under good conditions 30-40 years.
As for weight, I've got some culverts with 6" of dirt over the top and they withstand vehicle traffic including semis loaded with grain. Properly installed a culvert will withstand a LOT of weight.
I know nothing about the cost of a concrete culvert so can't speak to that.
  • Good Post
Reactions: JJT
   / Culvert Install #6
culverts are supported on all side by dirt so as long as the dirt doesn't move the culvert as no way to move therefore it is near impossible for it to collapse...
   / Culvert Install
That is on the short list of things to do.
   / Culvert Install #10
I had originally thought about making a bridge out of free I-beams I got from a friend, but then got my hands on a cheap 18" reinforced concrete pipe ($100). It seemed to me that dropping a pipe in a hole and coving it with dirt would be easier. The culvert location is 1/3 of a mile from the barn down a steep hill and along a trail. Bobby Branson handled the pipe shuttle no problemo. I am estimating this pipe to be in the 1800 lb range (I could be wrong though).View attachment 767606View attachment 767607
Nicely done. (y)
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
Mini SUV (A59231)
Mini SUV (A59231)
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A56436)
2-Row Peanut...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
VERMEER PD10 PILE DRIVER (A60429)
VERMEER PD10 PILE...
2018 John Deere Z997R (A53317)
2018 John Deere...
