Y'all Been Checkin' Lumber Prices?
/ Y'all Been Checkin' Lumber Prices? #1,461
Went in to a local building supply last week to pick up 6' of flex watertite conduit and a 90 and a straight fitting. Price on line was $38 which for what it is, is ridiculous but you don't have a choice. Got to the store the tag under it said $26, got to the register and it was $38 which I pointed out to the cashier didn't match the tag. "Ohh, we haven't got around to changing the tags yet" suck it up buttercup, $26 please and she did. So it went up $12 in one shot.
I was also informed they won't have that problem soon enough as they're going with electronic tags on all their shelves which will be controlled by their head office. They'll be able to gouge faster and better, gotta love technology
/ Y'all Been Checkin' Lumber Prices? #1,462
That looks familiar! What surprised me is how well the tracks stay in line once they bolt up. You might want to stabilize it a bit better though. Once you start putting logs on it and turning them, I fear that your blocks may not stay in place.
this is just until I can mill some 6x6 Timbers and about 200sf of board flooring so i can build the floor and posts for a real wooden sawmill shed. I am going to assemble it and make a bunch of stickers first, to dial in adjustments and vibrate/settle the current mishmash in a bit beforemdoing a re-level with shims to adjust footing Angles prior to cutting the real limber, then relocate the mill onto the deck platform while cutting the beams and boards for the roof.
but yeah, right now the setup is a bit on the sketchy side 🤣😂🤣 please look at my signature line below…
/ Y'all Been Checkin' Lumber Prices? #1,463
The stores I shop at charge the posted price, regardless what it rings up on the register. If they try to charge me more I'd just let them restock it.
/ Y'all Been Checkin' Lumber Prices? #1,464
$3.97 for prime 2x4s. Birch plywood for a woodworking project was $69/sheet. :(
/ Y'all Been Checkin' Lumber Prices? #1,465
It seems that anything that requires a peeler tree, as in making plywood, is what is expensive. I don't see too much other crazy pricing. Well, I'll retract that, in that, I was looking at very small plex tube connectors and was a bit shocked. :)
/ Y'all Been Checkin' Lumber Prices? #1,466
There must have been some sort of mistake. Because i bought four 2X4, 20 footers, doug fur construction grade, at 12.88 each. I even had to go recheck the reciept, and that is what they costed. .
You can definitely find deals on odd sizes that arent normally used in construction.
/ Y'all Been Checkin' Lumber Prices? #1,467
Two stores I checked and Advantech OSB 3/4" T&G is about 55$ a sheet.
/ Y'all Been Checkin' Lumber Prices? #1,468
Getting a little further along, and there is a tractor in the photo to boot!
I broke down and got out the shovel and leveled several of those blocks, primarily to keep MrsKilroyJC happy. . .
Maybe by this coming weekend I will be making big pieces of wood into little pieces of wood 😂🤣
/ Y'all Been Checkin' Lumber Prices? #1,469
Winding down assembly of the sawmill. The only items left to assemble are the lift crank, lifting cables, coolant tank and lines, and final squaring and alignment.
no work on it tomorrow - we will be going to our town’s Pumpkin Fest, the highlight of which is a competition in which pumpkins are rolled from the top of Town Hill and whoever’s pumpkin rolls the furthest wins. Then in the evening, we are going on a haunted hayride (all proceeds go to the local animal shelter).
I hope that by Monday there will be clouds of sawdust wafting on the breeze!
I have eight logs stacked to mill, the poplar will be made into stickers for drying lumber, and the walnut will be made into boards for interior paneling at our house.
Then, the felling of trees will be begin in earnest - I have about 18 pines and a dozen poplars already picked out for the initial clearing, and a couple other miscellaneous trees as well.
The first batches of
slabwood will become a scrap-rack, where subsequent off-cuts will be stacked to be cut into firewood lengths, and then lumber for the construction of a permanent sawmill shed will be stacked on pallets to dry. Followed by lumber for a real outhouse, a hunting shack, and my long-delayed outdoor kitchen.
I am SOOOOOO looking forward to getting this thing fired up!!!!
/ Y'all Been Checkin' Lumber Prices? #1,470
I used to get 2 x 4s for about $2.00. Then they went up to $7.13 a year or so ago. Last week they were $3.69. Plywood is still crazy. Not many options though if you want to keep working on projects or need the material.
/ Y'all Been Checkin' Lumber Prices? #1,471
Last I checked, 3/4" CDX was $80 out the door at HD. Should come down.
I read that container shipping has plummeted 85% due to drop in demand.
/ Y'all Been Checkin' Lumber Prices? #1,472
Just purchased fire rated plywood in 4 x 8 sheets. $87.00 a sheet. It was $112 from same supplier at last purchase 4 months ago.
/ Y'all Been Checkin' Lumber Prices? #1,473
I just checked and the stuff that is most like 3/4" CDX at my local HD is 23/32 in. x 4 ft. x 8 ft. RTD Sheathing Syp for $42.78/sheet.
I must be missing something here. Screencaps taken just a few minutes ago.....
Why is your store literally twice the price?
/ Y'all Been Checkin' Lumber Prices? #1,475
Yup you are LOL. How much we get hosed in Canada, Nova Scotia to be exact.
Taking the exchange into account your US$19 is CAN$26. If you go the 'tuther way, my CAN$38 is US$28. Why.....d**ned if I know, and it's pretty much the same on everything
/ Y'all Been Checkin' Lumber Prices? #1,476
I recall when my wife and I started dating in the late 70's through when we got married in the mid 80's, we'd go up to Canada, exchange a few hundred dollars in case we needed it, spend 3-4 days up there, not buy too much, exchange back to US, and they'd hand us more than we came in with. It was crazy.
Below, US Canadian exchange history
/ Y'all Been Checkin' Lumber Prices? #1,477
^^ you could have done that every week and quit your job. Who knew? :ROFLMAO::ROFLMAO:
/ Y'all Been Checkin' Lumber Prices? #1,479
I was on a trip through Oregon last week. The mills by the road had the biggest log decks I have ever seen. Not just one deck but deck after deck of logs. They had a lot of lumber too. One plywood mill had a huge number of bales of plywood stacked up and sitting in the rain. Are mills holding back to keep prices up?
/ Y'all Been Checkin' Lumber Prices? #1,480
Those are winter log decks. Mills stockpile logs in the fall in case it’s not possible to cut and haul during winter months.
2019 John Deere 4044M (A62177)
2019 John Deere...
2020 John Deere HPX615E Gator 4x4 Diesel Utility Cart (A61572)
2020 John Deere...
2013 FORD F350 SUPER DUTY 4x4 CREW CAB PICKUP TRUCK (A59910)
2013 FORD F350...
EZ Trail 3400 (A63118)
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2012 Freightliner M2106 Bucket Truck, Terex Hi-Ranger HR52M, 52FT Platform Height (A63118)
2012 Freightliner...
