John Deere 790 - What is this
/ John Deere 790 - What is this #1
fatboy95
John Deere 790
I have always wondered what the gold? piece is on my tractor.. can someone explain what the purpose is? sorry if this is a silly question but I gotta know.
/ John Deere 790 - What is this #2
Huh, my neighbor has one and has the same clamp. I always assumed it was a machinist's clamp that he put there for some reason. Guess I was wrong.
/ John Deere 790 - What is this #3
Surely looks like part of the locking mechanism for the loader frame. When removing that loader that front crossbar comes with it and act as the stand.
/ John Deere 790 - What is this #4
Had a 790...you're right!!!
I looked at this thread an hour or so back. My 790 (traded off years ago) had the same clamp...trying to remember why it was there was driving me nuts!!
Pretty sure it clamps to the weight bracket
/ John Deere 790 - What is this #5
JD had some early results of people ramming into objects (i.e stumps, rocks, abutments, etc. ) and bending that closing plate in the front, to the point that the plate was not holding the FEL tight enough that bumpy travel was allowing the FEL to come off. So the safety device (Clamp shown) was issued to all early customers (I was one) and then became standard part with the new FEL's.
I don't use it, but do put a 3/4" bolt through the front plate and the front weight bar. That keeps the plate from coming unlatched.. plus I don't ram into things to bend up that front plate.
/ John Deere 790 - What is this #6
I normally removed the loader unless there was a need for it
/ John Deere 790 - What is this #7
Doh! I can only imagine bumping across the back yard, when the loader falls off! :oops:
Reminds of what an old friend used to tell me when we'd get his tractor into deep mud, "if we get this thing stuck, there ain't nothing in the neighborhood big enough to pull it out!"
/ John Deere 790 - What is this #8
I remove mine when not needed, but always when winter comes and the snow plow goes on. But this quick tach FEL is easy to switch back and forth. The safety latch/bracket in question is not needed if the parts in front are not bent up and remain straight. But apparently there were a few instances early on where the FEL came off and caused some concern, but was a result of abusive use of the tractor. The type that can wreck/destroy an anvil.
I dont feel so bad now...lol. I've owned the 790 for about 6 years now.. I asked my FIL who is a tractor guy and didn't know either.. so i don't feel so bad when I scratch my head trying to figure it out. I don't see it doing anything but sitting on the front bracket.. it holds nothing g atm. I thought maybe a lock for front weights? I will take better pics of mine tomorrow.
/ John Deere 790 - What is this #10
Only keeps you from opening/releasing the latch on the front weight bar, which is needed to lower the frame and remove the FEL. Have to remove it first before removing the FEL.
/ John Deere 790 - What is this #11
I had one of those tractors back in the early 2000s. Several months after buying the tractor I received that part in a shipment with a letter from JD with installation instructions. Apparently under some circumstances, the quick attach loaders of that era actually quick attached when in use. That bracket is added insurance against the loader detaching inadvertently.
I understand what it does now.. thanks everyone.
2023 WEILER S350 SKIDDER (A65056)
2023 WEILER S350...
KOMATSU WA-250 GP Bucket (A68134)
KOMATSU WA-250 GP...
2005 FRAC TANK 500BBL WHEELED (A68842)
2005 FRAC TANK...
2012 FORD F-550 SUPER DUTY (A67714)
2012 FORD F-550...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
2012 TREMCAR CRUDE OIL TRAILER (A67714)
2012 TREMCAR CRUDE...
