power tool recommendation
/ power tool recommendation #1
tstex
Alleyton, Texas; Houston, TX
1997 Kubota M5400S
hello to all,
it's hard to believe the reviews online, so I am asking any of you that have owned a power washer for at least 2-4 yrs and like the results, what do you use? Looking for something w 2500-3000psi, for both home and ranch operations. Unfortunately my grew legs and it is gone. I still have the hoses, wand, attachments and other. Looking for a reliable make & model.
really would appreciate what you like about it and it's performance. if you have one that's been performing poorly, that's good to know too.
thank you very much,
tstex
/ power tool recommendation #2
Most the box store stuff is disposable. Troy built, Honda you name it
My buddy has a generac with a 420cc motor on it. It's a pretty good machine. PSI really doesnt mean anything. Flow rate it what cost more. Iirc it's a 4ish GPM machine
I work on commercial aaladdin machines and they are nice but way over kill for home use
/ power tool recommendation #4
I'm beginning to believe anything with a Honda motor on it is ok....
I have a Honda unit in my barn. Pump died but the motor still runs. It was only a year or 2 old when it died. Relief valve died and couldn't order a new one. It seized up and would over pressurize and stall the motor
Thanks
What was the brand w the Honda engine?
Thanks on the generac lead shred.
/ power tool recommendation #7
Iirc it was sold as a honda branded unit. I just need a use for a vertical shape 5hp
/ power tool recommendation #8
Let your pocket book decide. I have the JD 3800 series with the Honda engine. I purchased the unit at Lowes years ago. It had a defective gas tank when sold. The original purchaser brought it back. Lowes had it at a you just stole this price in there as is area. I sat down on a zero turn got out the smart phone and located a tank. Offered 25 dollars less than they were asking and loaded it on the truck. Three days later I had the new gas tank on it.
Regardless of the unit you finally decide to purchase always turn the water on before you start the motor. Also avoid prolong running of the motor without passing water through the pump.
Also make sure the unit has a soap or wash detergent dispenser.
Lowes offers this Honda powered unit today.
/ power tool recommendation #9
Don't listen to this guy.
Honda makes several levels of engines, GX engines will last pretty much forever. My pressure washer is 12 years old now and I use it pretty extensively, the pump is almost worn out but the GX engine still starts first pull. I just bought a GX trash pump I believe from the 70s that was very abused, new rings and a clean carb now she also cranks first pull and I run it about 1,500 gallons a week for animal and garden water from my pond.
/ power tool recommendation #11
The engine is great. Still starts right up
It was the cheap pump that was junk
Whatever was made 12 yrs ago is prob 10-15 x's more reliable and robust than anything made today. Mine was a craftsman 2800psi and it worked very well. Just had to make sure it had the proper amt of oil in it....
Any yes, I ALWAYS crank on the water, purge out all the air via the wand, once a steady stream, I cranked it. The water going thru is like it's radiator to keep it from over heating...
/ power tool recommendation #14
Also make sure the hose is flushed out and clean before you hook it up to the pressure washer. Expensive lesson learned due to my hired help getting dirt in the hoses when relocating pump on job site. Just a tiny bit of sand will ruin the pump assembly. I now have a bowl type screen filter on the unit to keep the sand out. Learned from a rental place to install the screen unit. Seems its a somewhat common problem for them.
/ power tool recommendation #15
I thought Honda didnt make pressure washers. seems like the closest thing to one is everyone elses brand pumps with Honda power.
Whats Honda'S model number on yours?
/ power tool recommendation #16
Not sure. I thru away everything but the motor a few years ago
/ power tool recommendation #17
craigslist. any karcher pressure washers with a honda engine. for long life.... non ethanol gas and end of year flush pump with something like
STA-BIL Pump Protector.
/ power tool recommendation #18
what do you guys think about this one ? it has over 4000 reviews and majority are 5, then 4...reasonably priced. The engine is make by Kohler, which are good engines...
The specs look good. I could not see the carb good enough to determine if it has a fuel shut off. I like this feature on a unit because we use the unit today and a year later we have use for it again. I turn the fuel off and let the unit run until it cuts itself off because of the lack of fuel. It is much easier to just tilt the unit over and pour stale gas out of the tank and not have to also remove and clean the carb.
Another feature the unit says it has is the use of “Chemicals And Detergents.” Most specify the use of pressure washer soap detergents only. It would be interesting to see exactly what chemical they are talking about.
/ power tool recommendation #19
I have a unit with a Honda engine. It's over 24 years old. Doesn't make the pressure that it did when new. But more than sufficient for cleaning anything I have. I would be very wary of all these new plastic units. They come with built in - engineered obsolescence.
/ power tool recommendation #20
Honda makes pressure washers for sale in Japan. Honda America does not offer the units for sale in the US. In the US we have Honda Powered pressure washers made by different manufacturers.
1995 Kiefer Built Gooseneck Trailer (A66285)
1995 Kiefer Built...
Swict 66in Bucket Skid Steer Attachment (A64553)
Swict 66in Bucket...
2018 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2018 KENWORTH T680...
2014 CATERPILLAR 938K WHEEL LOADER (A64279)
2014 CATERPILLAR...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
