Rotary cutter rear u-joint shield??
   / Rotary cutter rear u-joint shield?? #1
Bobrown14
Gold Member
Upstate New York
LS MT352 w/power shuttle + cab
20221012_170735-jpg.766130
OK blew up my shield on my rotary cutter at the back end of my drive shaft where the shear pin is.
Shear pin broke and blew a hole and completely shattered tre shield. Pics attached.
Where can I purchase a new shield?
Rotary cutter is a Titan 1206.
Btw went thru a bag of shear bolts clearing some heavy over tractor cab high brush. Bout 10ish years old (the brush).
Any help sourcing the shear bolt cover greatly appreciated.
   / Rotary cutter rear u-joint shield?? #2
If it were mine, I’d just wrap duct tape around it if there is enough plastic material left to do that. A new one would probably end up in the same situation, and they’d probably charge you an arm and a leg.
   / Rotary cutter rear u-joint shield?? #3
Shouldn't be too hard to find. I found this in about 30 seconds...
   / Rotary cutter rear u-joint shield?? #5
Contact Titan and ask who their PTO parts supplier is. You may be able to buy direct.
Your local tractor dealer probably can help.
   / Rotary cutter rear u-joint shield?? #6
Titan won't sell direct, but most any tractor supply will have one. Also, going through sheer bolts like that, I think I would consider a slip clutch.
   / Rotary cutter rear u-joint shield?? #9
You need some grade 10 shear bolts.
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
John Deere 750 Drill (A50514)
John Deere 750...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
Maverick 3250 Excavator Hammer (A50774)
Maverick 3250...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
6ft Single Gang Disc (A52128)
6ft Single Gang...
