Rotary cutter rear u-joint shield??
   / Rotary cutter rear u-joint shield?? #1
Bobrown14
Upstate New York
LS MT352 w/power shuttle + cab
20221012_170735-jpg.766130
OK blew up my shield on my rotary cutter at the back end of my drive shaft where the shear pin is.
Shear pin broke and blew a hole and completely shattered tre shield. Pics attached.
Where can I purchase a new shield?
Rotary cutter is a Titan 1206.
Btw went thru a bag of shear bolts clearing some heavy over tractor cab high brush. Bout 10ish years old (the brush).
Any help sourcing the shear bolt cover greatly appreciated.
   / Rotary cutter rear u-joint shield?? #2
If it were mine, I’d just wrap duct tape around it if there is enough plastic material left to do that. A new one would probably end up in the same situation, and they’d probably charge you an arm and a leg.
   / Rotary cutter rear u-joint shield?? #3
Shouldn't be too hard to find. I found this in about 30 seconds...
   / Rotary cutter rear u-joint shield?? #5
Contact Titan and ask who their PTO parts supplier is. You may be able to buy direct.
Your local tractor dealer probably can help.
   / Rotary cutter rear u-joint shield?? #6
Titan won't sell direct, but most any tractor supply will have one. Also, going through sheer bolts like that, I think I would consider a slip clutch.
   / Rotary cutter rear u-joint shield?? #9
You need some grade 10 shear bolts.
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
John Deere 16 Row Cultivator (A50514)
John Deere 16 Row...
Komatsu PC138 (A50490)
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
ATLAS 1985 SCL120 10' ROTARY MOWER (A51243)
ATLAS 1985 SCL120...
