Rotary cutter rear u-joint shield??
   / Rotary cutter rear u-joint shield?? #1
Bobrown14
Gold Member
Upstate New York
LS MT352 w/power shuttle + cab
20221012_170735-jpg.766130
OK blew up my shield on my rotary cutter at the back end of my drive shaft where the shear pin is.
Shear pin broke and blew a hole and completely shattered tre shield. Pics attached.
Where can I purchase a new shield?
Rotary cutter is a Titan 1206.
Btw went thru a bag of shear bolts clearing some heavy over tractor cab high brush. Bout 10ish years old (the brush).
Any help sourcing the shear bolt cover greatly appreciated.
   / Rotary cutter rear u-joint shield?? #2
If it were mine, I’d just wrap duct tape around it if there is enough plastic material left to do that. A new one would probably end up in the same situation, and they’d probably charge you an arm and a leg.
   / Rotary cutter rear u-joint shield?? #3
Shouldn't be too hard to find. I found this in about 30 seconds...
   / Rotary cutter rear u-joint shield?? #5
Contact Titan and ask who their PTO parts supplier is. You may be able to buy direct.
Your local tractor dealer probably can help.
   / Rotary cutter rear u-joint shield?? #6
Titan won't sell direct, but most any tractor supply will have one. Also, going through sheer bolts like that, I think I would consider a slip clutch.
   / Rotary cutter rear u-joint shield?? #9
You need some grade 10 shear bolts.
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2018 Wacker Neuson WL 38 (A52128)
2018 Wacker Neuson...
2019 JOHN DEERE 331G SKID STEER (A51242)
2019 JOHN DEERE...
UNUSED FUTURE MINI EXCAVATOR RIPPER (A51244)
UNUSED FUTURE MINI...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
